POV-Ray : Newsgroups : povray.beta-test : Rerender insert menu bitmaps Server Time
20 Sep 2024 19:03:07 EDT (-0400)
  Rerender insert menu bitmaps (Message 1 to 4 of 4)
Subject: Rerender insert menu bitmaps
Date: 11 Oct 2010 14:32:06
Message: <4cb35826$1@news.povray.org>
This did not work for me after a fresh install due
to IO restrictions set to read only. I'm not sure if
it was like that in 3.6 too, or if it is a side effect
of moving the Insert Menu to user documents. In any
case, there is no mention of it in 1.5.8.10.8.
Tested on Windows 7 64-bit although I suspect it doesn't
matter, as it's a permission setting of POV-Ray itself.
It would be convenient if it just worked. Of course,
a malicious virus could then spread by overwriting the
pov files in the insert menu folder. ;)
I also stumbled across a parse error in shapes.pov,
but that was already reported as FS#82.
Subject: Re: Rerender insert menu bitmaps
Date: 11 Oct 2010 14:33:50
Message: <4cb3588e@news.povray.org>
... and 3.7 beta 39.
Date: 13 Oct 2010 05:08:55
Message: <4cb57727$1@news.povray.org>
No such problem on XP with 3.7 beta 39
(but shapes.pov is buggy anyway)
My PVENGINE.ini got
[Permitted Output Paths]
1=%PROFILEDIR%\Insert Menu
I did not play with it, but maybe it has some effects.
(I cannot remember if the install was "user only" or system wide)
[Permitted Input Paths]
1=%INSTALLDIR%
2=%PROFILEDIR%
3=%FONTDIR%
Real software engineers work from 9 to 5, because that is<br/>
the way the job is described in the formal spec.  Working<br/>
late would feel like using an undocumented external procedure.
Date: 14 Oct 2010 16:57:44
Message: <4cb76ec8@news.povray.org>
Le_Forgeron wrote:
> My PVENGINE.ini got
Hmm ... I don't see these two sections in my pvengine.ini.
Manually adding the Insert Menu path solved the problem.
Not sure why they were missing. I did a system wide
install using the same account I start it with.
