POV-Ray : Newsgroups : povray.beta-test : Shift of interpolated images Server Time
25 Apr 2026 23:52:09 EDT (-0400)
  Shift of interpolated images (Message 11 to 15 of 15)
Subject: Re: Shift of interpolated images
Date: 1 May 2010 03:45:01
Message: <web.4bdbdab672a6f2d8ae92d9930@news.povray.org>
> Hmm, I'm wondering if something in my own 'reproduction' code is the fault here.
> Since I'm re-rendering typical 4/3 images, the box that they're applied to is
> this (with the camera at x=0,y=0 and look_at the same):
> box{
> pigment{image_map...}}
> translate <-.5,-.5,0>
> scale <4/3,1 1>
> The 4/3 scaling is the only oddity I can think of.
Nope; I just did a far-simpler test (square box, square image_map, no
'motion-blur' code at all) and I still see the bottom-LEFT shift.  So I'm still
puzzled. Perhaps there's been some kind of change between v3.6.1 and one of the
betas?
Ken
Date: 1 May 2010 04:02:09
Message: <4bdbe001$1@news.povray.org>
Am 01.05.2010 08:59, schrieb Kenneth:
> I was somewhat aware of this; I think fixing it would be a good idea. But I'm
> wondering about that bottom-right shift.
> So I did some tests in v3.6.1, using this image_map chart (with interpolate 2)
> and the same 'copying' step as mentioned above. What I see is that the 'blur' is
> shifted to the bottom-LEFT. (And also downward; sort of a combination of the two
> directions.) I've posted some images of the tests over at p.b.i.--I can't seem
> to do it here. (The orange lines correspond to your non-moving 'center dot.')
Duh - now that you mention it, I realize that my test setup mirrors the
test image horizontally. So yes, you're right: It is a shift to the
bottom-LEFT with respect to the original picture.
Date: 1 May 2010 06:35:00
Message: <web.4bdc035272a6f2d8ae92d9930@news.povray.org>
Ah, the ol' mirror-trick, eh? So I guess something *did* change since
3.6.1--'clipka's mirror.' ;-P
Date: 3 May 2010 04:50:00
Message: <web.4bde8d2f72a6f2d8ae92d9930@news.povray.org>
> ...Test #2 was re-rendered a 8-times the original--5760 x 4320--and NOT blown
> up in P.Shop. (Although I *have* included a blown-up close-up of that.) Again,
> it looks like a full-pixel shift.
Sorry, I was mistaken about that; it *is* a 1/2-pixel-shift, in the context of
what is meant here. (I got confused about what '1 pixel vs. 1/2 pixel' meant.)
For Clipka:
Something else that occurs me to me about my posted image tests (something
obvious, and you probably realized this already) is that the 1/2 shift during
interpolation is a shift *based on the original pixels of the image_map* (NOT a
1/2 shift in the pixels of the *re-rendered* image of the image_map.) To help
explain that more clearly: My 720 X 540 test chart with its single-pixel-lines,
when re-rendered at 8X its size, creates 8-pixel-wide lines; that's perfectly
understandable. But when interpolated, it creates an 8-pixel shift to the left
and down (i.e., not 1/2 or 1 pixel as I would have expected.)  With the
interpolate 'blur' filling an area of 16 pixels--twice the width of the 8-pixel
line. I wonder if this behavior makes sense?  Don't know; I would have expected
far less blur and far less 'movement' in such a case.
What this seems to mean is that the shift that we currently see (and the
'amount' of interpolation) is based on the magnification factor when
re-rendering the image_map's pixels. For example, say the image_map is on a box
that's deep into z, so that it re-renders at a fraction of its real size. (Which
is usually the case.) In such a case, the re-rendered shift would be far less
than 1/2 pixel, to my mind. Which I *guess* is a good thing(?)
I don't quite know what to make of this; but I thought I'd mention it. It may
have a bearing on how you figure out your corrections.
Ken
Date: 22 Jun 2010 13:55:00
Message: <web.4c20f7ef72a6f2d8f72d690e0@news.povray.org>
> As can quite easily be seen, when interpolation is activated the image
> appears slightly shifted to the bottom-right, in the order of magnitude
> of half a pixel.
> Normally I'd just fix that offset, but it has probably been there since
> eons - and changing it might actually break a few scenes that have
> deliberately worked around this issue (I have at least once designed
> such a scene).
> How do you feel about it?
Since it would probably eliminate the diagonal drifting of images for things
like ripple tank and CA sims, I'm all for it.
