POV-Ray : Newsgroups : povray.beta-test : Linux beta image output whacky Server Time
25 Apr 2026 20:05:15 EDT (-0400)
  Linux beta image output whacky (Message 1 to 4 of 4)
Subject: Linux beta image output whacky
Date: 22 Mar 2010 21:31:34
Message: <4ba819f6@news.povray.org>
I just compiled the official beta.35a sources for Linux, to find that
there's something whacky about it; here's how it renders the sample
scenes "abyss.pov" and "fractals2.pov".
I'm running openSUSE 11.2 (x86_64) on an AMD Phenom 9650 2.3GHz system
with 6GB RAM; POV-Ray 3.7.0.beta.35a was compiled with g++ 4.4.
The symptoms can be seen with TGA and JPG output as well, but not with
HDR or PPM, so obviously the error is somewhere in the image file
generation.
It appears that in the offending cases, color components with a zero
value are "upped" to a value of 255 instead (or maybe "downed" to -1,
hard to tell).
Strange thing is:
- Only a few images seem to be affected, and even in the affected images
not all parts suffer the effect (for instance, when turning all lights
off in abyss.pov, the parts that are pink now will show up white, while
everything else will be pitch black except for a few white specks).
- The symptom did not occur with previous betas I had compiled with
Intel's icpc compiler; however, I had to recompile those recently, and
couldn't get the icpc to do the job anymore for unknown reasons, so
recompiled them with g++ 4.4 as well, and now I see the same symptom
with those as well.
- The symptom does not occur on Windows.
Can anyone confirm? This error looks really freakish to me at present.
Download 'abyss.pov.png' (366 KB) Download 'fractals2.pov.png' (882 KB)
Preview of image 'abyss.pov.png'
Preview of image 'fractals2.pov.png'
Subject: Re: Linux beta image output whacky
Date: 23 Mar 2010 10:24:27
Message: <4ba8cf1b$1@news.povray.org>
I managed to track down the issue to the output file gamma correction,
which uses the following pattern for all of the offending file formats:
     encodedR = (unsigned char) floor (
         clip(powf(r, gamma), 0.0f, 1.0f) * 255.0
(and correspondingly for G and B channels)
Obviously, this goes bonkers when r is negative (which is physically
nonsense, but may happen with some exotic scene constructs) and gamma
does not happen to be an integer value. In such cases, the result of the
powf() function will be #NaN ("Not a Number").
Apparently, something in the expression
     (unsigned char) floor (clip(#NaN, 0.0f, 1.0f) * 255.0)
is compiler-dependent, with Microsoft and Intel compilers returning 0
but g++ returning 255.
The proper solution would be to clip to positive values /before/
gamma-adjusting; given that any number smaller than 1.0f raised to
whatever positive power will give a result smaller than 1.0f, while any
number greater than 1.0f raised to whatever positive power will give a
result greater than 1.0f, the clipping to a maximum value of 1.0f can
also safely be performed before gamma-adjusting. Thus, the offending
statements should be changed to the following pattern:
         powf(clip(r, 0.0f, 1.0f), gamma) * 255.0
(I guess similar issues can be found in the HDR and PPM output code, but
those don't kick in because the file formats store linear data by
definition or convention, and therefore no gamma correction is performed
there with the scenes I used for testing.)
I'll file a bug report.
Date: 23 Mar 2010 18:32:03
Message: <4ba94163$1@news.povray.org>
Le 23/03/2010 15:24, clipka nous fit lire :
Have you tried to remove "-fastmath" (sp?) from the compilation option ?
It might help on the issue.
Date: 23 Mar 2010 22:00:46
Message: <4ba9724e$1@news.povray.org>
I'm not in need for any workarounds; the code needs fixing anyway, so
that's the way I'll be going. Thanks for sharing the idea though.
