POV-Ray : Newsgroups : povray.beta-test : Saving memory with HDRI Server Time
20 Mar 2026 10:44:06 EDT (-0400)
  Saving memory with HDRI (Message 1 to 2 of 2)
Subject: Saving memory with HDRI
Date: 25 Sep 2009 08:07:39
Message: <4abcb28b$1@news.povray.org>
It just occurs to me -
as the lookup table mechanism for gamma-correction has now been
implemented anyway, including a 16-bit variant:
What stops us from using the very same mechanism to handle High Dynamic
Range images?
OpenEXR uses "half-precision" floating-point numbers to store image
data; while at first glance they call for being converted to proper
floating-point values straight away, they are actually 16-bit values,
which could just as well be handled with a look-up table.
Radiance HDR uses 8-bit integers for each color channel plus a common
8-bit exponent; again, this combines to 16 relevant bits per channel.
Hum... maybe it's time to provide a command-line / INI file parameter to
choose between optimization for speed and optimization for memory
consumption.
Subject: Re: Saving memory with HDRI
Date: 25 Sep 2009 13:43:39
Message: <4abd014b@news.povray.org>
> Range images?
Waste of memory happens first of all because there is always that 5
channel 32 bit float image buffer used even for e.g. a simple 1 channel
grayscale OpenEXR file. Also for the most common case (3 rgb channels
without alpha) there are 2 channels "wasted".
While it indeed might be a good idea to implement a "half" image
container format (because this is not file format specific), I do not
believe there should be a container for every possible floating point
representation just because it is used by one even outdated (as Greg
Ward himself called it almost ten years ago) file format. Otherwise
there would be also need to implement luts for the LogLUV format and
others that are e.g. supported by TIFF (that also can store "half" data
and as mentioned almost everything else).
> consumption.
According to some benchmarking I've done (well, not with POV-Ray but
with random and sequential access to image data using 16 and 32 bit
floats there is no speed difference even if the conversion from 'half'
to 32 bit 'float' requires a few clock ticks. Guess it has to do with
better utilization of the cache line or whatever.
Note also that 'half' is implemented as class by ILM and the conversion
from 'half' to float (automatically done when e.g. using the "="
operator) is there already implemented by using a LUT.
The problem is that someone might want to compile without support for
OpenEXR.
-Ive
