POV-Ray : Newsgroups : povray.beta-test : Suspicious PGM/PPM file format handling Server Time
16 May 2026 00:37:01 EDT (-0400)
  Suspicious PGM/PPM file format handling (Message 1 to 5 of 5)
Subject: Suspicious PGM/PPM file format handling
Date: 14 Sep 2009 08:49:13
Message: <4aae3bc9@news.povray.org>
While digging through the image reading code for PGM and PPM files, I
noticed something strange regarding the handling of the "maxvalue"
header field:
(A) In PPM files, the value appears to be consistently interpreted as
the value that would represent 1.0. The same applies to PGM files with a
"maxvalue" of 255 or less.
(B) For PGM files with a "maxvalue" of 256 or higher however, maxvalue
appears to be effectively ignored, and the values interpreted as if
65535 would represent 1.0.
Can someone confirm this in practice?
Any suggestions how to handle this? I would consider (B) a bug and
change it - even at the cost of potentially breaking existing scenes,
speculating that most files with a "maxvalue" > 255 do have a value of
65535 anyway.
Subject: Re: Suspicious PGM/PPM file format handling
Date: 14 Sep 2009 09:24:15
Message: <4aae43ff$1@news.povray.org>
> 65535 anyway.
B is a bug and your speculation is valid.
There are indeed some (but very rare) PNM files that seem to assume
"maxvalue" is the maximal value that *appears* within the image out of
the full range of 0-65535 but this is a bug within the used PNM-writer
and shouldn't become our problem.
-Ive
Date: 14 Sep 2009 10:46:31
Message: <4aae5747$1@news.povray.org>
Good.
Another thing: In the various file readers, I frequently encounter the
following construct:
   floatColor = ((intColor * 255) / intMax) / 255.0;
where intMax is derived from the bit depth of the color component.
Does this make any sense to you? Wouldn't it be more faithful to the
encoded data to decode it as
   floatColor = float(intColor) / float(intMax) ?
My initial assumption was that it's just lazy coding, with the /255.0
having been added when refactoring the code to use float values, but the
frequent appearance makes me uneasy.
Date: 14 Sep 2009 11:40:26
Message: <4aae63ea$1@news.povray.org>
Assuming floatColor was once a byteColor it really looks like a relict
of the once used MulDiv approach. I cannot see a reason for keeping that.
Ahem, and in case you came across tiff.cpp, could you please change the line
if (PhotometricInterpretation == PHOTOMETRIC_PALETTE)
to
if ((PhotometricInterpretation == PHOTOMETRIC_PALETTE) &&
(TIFFIsTiled(tif) == 0))
This will prevent POV-Ray from having a few pointers running wild when
someone tries to use a color palette TIF-file that happens to be tiled
and is not arranged in strips.
-Ive
Date: 14 Sep 2009 11:56:24
Message: <4aae67a8$1@news.povray.org>
> line
> to
Done. I have not much of an idea what it is for, but I trust you on this
one :-)
I'll include that with the gamma handling stuff.
