![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ain't this sweet?
PNG properly defines how gamma should be handled in the presence of a
gAMA chunk.
POV-Ray 3.6, when used with assumed_gamma, respects this definition
flawlessly... for 24- and 32-bit images, that is.
For 8-bit color palette PNG images, POV-Ray 3.6 doesn't give a damn
about gamma correction.
Likewise, the PPM format properly defines how gamma should be handled
*always*.
POV-Ray 3.6 gives a piece of sh*t about this definition.
So, how should one go about this in POV-Ray 3.7? Emulate all those
crappy details? If so, when? Only when #version is set to 3.6? Always
when the legacy assumed_gamma statement is used (which is supposed to
not be used for new scenes)?
Can of worms indeed...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> *always*.
Err, where did you get this from. In case you are referring to the
NETPPM toolkit and its CIE/ITU Rec. 709 specification you should be
aware that this is only valid for files written by this toolkit and not
for pgm/ppb/pbm/pnm files written by one of the numerous other
applications in the UNIX world. Therefor pnmgamma (to gamma-correct
other files) is part of this toolkit.
-Ive
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ive schrieb:
>> *always*.
Yes, that's exactly the source I had it from, and even that actually
also notes that "a common variation on the PPM format is to have the
sample values be 'linear,'", which I had perfectly failed to notice.
As I said, the summary you provided on gamma handling in various file
formats is greatly appreaciated :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
