POV-Ray : Newsgroups : povray.beta-test : Gamma in POV-Ray 3.6 vs. 3.7 Server Time
4 Feb 2026 07:23:26 EST (-0500)
  Gamma in POV-Ray 3.6 vs. 3.7 (Message 71 to 75 of 75)
Subject: Re: Gamma in POV-Ray 3.6 vs. 3.7
Date: 15 Sep 2009 09:26:04
Message: <4aaf95ec$1@news.povray.org>
MDenham wrote:
> 1) the axis of anisotropy
> 2) the "ordinary" axis
> It turns into a useful (though limited) form of the otherwise not-gonna-happen
> "variable ior" request thanks to this.  (Generalized variable ior isn't going
> to happen for reasons that are mentioned in the documentation, such as
> "pockets" of high IOR - or even not-so-high IOR - having potentially
> pathological behavior.  You'd need to switch to a solely
> rays-start-at-light-sources approach - photons, only slower - to make this even
> slightly viable, and that kind of rewrite probably isn't worth it.  [If it turns
> out that it's necessary for a "good" spectral system, then we may have issues.
> :-D])
Ah, and here I was thinking it was just as simple as tracing a second
refraction ray.
Bummer.
~Mike
Date: 16 Sep 2009 20:17:50
Message: <4ab1802e$1@news.povray.org>
> clipka wrote:
>> Hey, get real: You need to press the "shift" key for quite a host of
>> things, I guess. As a German, for instance, I need to press "shift" to
>> get a multiplication asterisk, dividing slash, opening or closing
>> parentheses, quotes etc,
> And for all nouns too, right? :)
On my side, all the followings need two keys:
\!@#$%?&*()_ (Shift +...)
My Alt Char key is worn smooth...
Date: 16 Sep 2009 20:49:21
Message: <4ab18791$1@news.povray.org>
> Wondering, is ambient light (global setting) in rgb or just gray ?
It's a full rgb value. Whenever you provide only a single float
(ambient_lights 1), it get's promoted to a color vector (ambient_lights
<1, 1, 1>)
Setting "ambient_lights <1, 0.2, 5>" is perfectly valid.
Date: 16 Sep 2009 21:11:25
Message: <4ab18cbd$1@news.povray.org>
> clipka wrote:
>>> Maybe that's a part for media, not pigment.
>> Birefringence is definitively neither a media nor pigment thing, but a
>> straightforward interior thing, and would have to join ranks with ior
>> and dispersion (as a matter of fact it's a difference in ior depending
>> on polarization with respect to the "optical axis" of the (AFAIK
>> necessarily) crystalline material).
> How hard would it be to implement birefringence ...? Seems like it could
> easily be faked
> Syntax would be trivial:
> ior 1.5, 1.7 //(birefringent material)
> You don't really need to care about the polarization of light, since
> light in POVRay doesn't have polarity anyway.
> I would imagine tracing a second ray at a different IOR would be rather
> simple to add.
In addition of the second ior, you also need an axis or "direction".
If you take a sphere of birefringent material and make it turn, the
difference in refractions changes. It also changes depending on the
distance from the view axis.
There is a plane where both iors are the same and an axis where they are
the most different, usualy. They are frequently perpendicular, but I
think that there are cases where the axis is not normal to the plane...
I think that you "may" attempt to simulate it. Some experimentation in
view. Some layering and/or averaging would be required.
Date: 17 Sep 2009 19:45:00
Message: <web.4ab2c91c235fbd0ccf39c48a0@news.povray.org>
> > easily be faked
> > simple to add.
If the "axis" isn't normal to the plane, you're working with something with at
least two axes of anisotropy.  (This would be a _much_ harder case to work with.
 Uniaxial birefringence is probably doable; trying to write it to handle two or
more axes will result in programmers chasing you with hatchets. :-D)
