POV-Ray : Newsgroups : povray.beta-test : compile error: 'CLOCK_PROCESS_CPUTIME_ID' was not declared in this scope Server Time
26 Jul 2026 23:45:48 EDT (-0400)
  compile error: 'CLOCK_PROCESS_CPUTIME_ID' was not declared in this scope (Message 11 to 13 of 13)
Subject: Re: compile error: 'CLOCK_PROCESS_CPUTIME_ID' was not declared in thisscope
Date: 16 Jul 2009 16:33:49
Message: <4a5f8ead@news.povray.org>
On Thu, 16 Jul 2009 15:33:38 -0400 marabou wrote:
> On Thu, 16 Jul 2009 10:11:54 +0200 Le_Forgeron wrote:
>> Le 15/07/2009 19:40, clipka nous fit lire :
>>> Le_Forgeron <jgr### [at] freefr> wrote:
>>>> Now, CLOCK_PROCESS_CPUTIME_ID is posix, so should we just hate
>>>> freebsd 7.2 and lower for not having it ? (no assertion about 8.0)
>>> Sounds like a reasonable option :P (SCNR)
>>> I'd say it depends on how complicated it would be to fix. At any rate,
>>> it's worth entering into the bugtracker as a compatibility issue. As
>>> you seem to be into details to some degree, would you mind...? kthxbye
>> Entry add in bugtracker, as per request.
> Povray does compile now. The patch follows. But there is another problem
> which is ugly:
> Making all in libraries
> Making all in source
> Making all in backend
> Making all in base
> Making all in frontend
> Making all in vfe
> Making all in unix
> ./unix/povray +i./scenes/advanced/biscuit.pov -f +d +p +v +w320 +h240
> +a0.3 +L./include
> povray: this pre-release version of POV-Ray for Unix has expired ***
> Error code 1
> Stop in /usr/home/user/sources/povray-3.7.0.beta.32.
> How can I circumvent it?
okay, fulfilled.
Sometimes Povray dumps core, sometimes it loops forever at this position:
Making all in base
Making all in vfe
Making all in unix
+a0.3 +L./include
povray: this pre-release version of POV-Ray for Unix expires in 3 day(s)
and 1 hour(s)
PATHS
  HOME        = /home/xxx
  SYSCONF     = /usr/local/etc/povray/3.7/povray.conf
  USERCONF    = /home/user/.povray/3.7/povray.conf
  SYSINI      = /usr/local/etc/povray/3.7/povray.ini
  SYSINI_OLD  = /usr/local/etc/povray.ini
  USERINI     = /home/xxx/.povray/3.7/povray.ini
  USERINI_OLD = /home/xxx/.povrayrc
PARSE CONF '/usr/local/etc/povray/3.7/povray.conf'
[still running@100% CPU time...]
There seems to be another problem.
GDB says:
#13 0x0yyyyyyy in SignalHandler () at unix/unixconsole.cpp:146
Previous frame identical to this frame (corrupt stack?)
(gdb) list 146
141		int      signum;
142
143		while(true)
144		{
145			sigfillset(&sigset);
146			sigwait(&sigset, &signum);  // wait till a signal
is caught
147			boost::mutex::scoped_lock lock(gSignalMutex);
148			gSignalNumber = signum;
149		}
150	}
(gdb)
Date: 16 Jul 2009 16:35:01
Message: <web.4a5f8ed435d6a577579432980@news.povray.org>
> *** Error code 1
From an older post:
1) run  ./povray --betacode  to obtain a time-limited code (integer value)
2) set the environment variable POVRAY_BETA with this code
3) repeat when the current code doesn't work anymore.
Unfortunately this information seems nowhere to be found on the official POV-Ray
beta test web pages.
> Another question:
> If Povray executes, how can I check if my patch is successful? Would
> Povray start? Would it crash? Which checks have to be done?
Just check whether the timing statistics (render time and such) seem plausible;
that's all that should be affected.
Date: 16 Jul 2009 16:45:00
Message: <web.4a5f902135d6a577579432980@news.povray.org>
> > So no need to loathe freebsd for this :)
> sorry, did you read all new posts in this thread?
No, sorry - you were typing too fast ;) (I'm using the message digest on
http://news.povray.org, not a news reader, usually reading the posts on a FIFO
basis ;))
But at first glance it looks to me like we need to loathe freebsd for something
else, not the time statistics stuff.
