POV-Ray : Newsgroups : povray.beta-test : unknown error code Server Time
19 May 2024 22:13:21 EDT (-0400)
  unknown error code (Message 1 to 4 of 4)
Subject: unknown error code
Date: 8 Jan 2009 16:18:11
Message: <49666d93$1@news.povray.org>
% povray input_file.pov
error code = -24
Unknown error code
In vfe/vfesession.cpp, I made a small change to print out the error code (I know I
could have used a debugger for this...):
const char *vfeSession::GetErrorString(int code) const
   if (code == -1)
     code = m_LastError;
   switch (code)
     case vfeNoError:
       return "No error";
   // added djconnel Jan2008
   fprintf(stderr, "error code = %d\n", code);
   return "Unknown error code";
In vfe/unix/unixconsole.cpp :
void ErrorExit(vfeSession *session)
	fprintf(stderr, "%s\n", session->GetErrorString());
	session->Shutdown();
	delete session;
	exit(RETURN_ERROR);
Pardon my c++ gross ignorance, but I'm not sure where the value of code is passed to
the GetErrorString(), although somehow it's getting an illegal value....  independent
of the source file.
Version information:
POV-Ray 3.7.0.beta.29
This is an unofficial beta-test version compiled by:
  djc### [at] yahoocom
It may not be distributed without written permission.
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
Built-in features:
   I/O restrictions:          enabled
   X Window display:          enabled (using SDL)
   SVGAlib display:           disabled
   Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
   Unsupported image formats: openexr
Compilation settings:
   Build architecture:  x86_64-unknown-linux-gnu
   Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
   Compiler vendor:     gnu
   Compiler version:    g++ 4.3.2
   Compiler flags:      -pipe -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs
-s -O3 -ffast-math -march=native -pthread
Subject: Re: unknown error code
Date: 10 Jan 2009 02:50:00
Message: <web.496852f4a2bee17bf3c0a050@news.povray.org>
> error code = -24
> Unknown error code
You did patch vfe.cpp, did you?
If you didn't, then the unknown error is no surprise since 2009-01-01, 00:00.
Date: 10 Jan 2009 05:46:34
Message: <49687C8A.9010506@yahoo.com>
No :).  I've been in southeast Asia, not following updates...
Ahh, the famous Y(2K+9) problem :)
I deleted the offending time check.
% diff vfe.cpp*
747a748,753
 >   // this code may not be removed or modified unless the compilation is for
personal
 >   // use and the binary is not distributed to anyone else.
 >   xtime_get(&t, TIME_UTC);
 >   if (t.sec > 1230760800)
 >     throw POV_EXCEPTION(kCannotHandleRequestErr, "Please obtain an updated version
of this application.");
thanks,
Dan
Date: 10 Jan 2009 09:01:31
Message: <4968aa3b$1@news.povray.org>
> updated version of this application.");
It seems to me this is an error: it throws an exception code, defined in
source/base/pov_err.h , yet enumerated values defined in vfe/vfesession.h are assumed
by vfeSession::GetErrorString(int code), which ends up getting invoked.
I'm not going to spend any time on it, though.... easy enough to delete the check.
Dan
