POV-Ray : Newsgroups : povray.beta-test : A note on #debug output in v3.7, beta 29 Server Time
2 Nov 2026 21:16:34 EST (-0500)
  A note on #debug output in v3.7, beta 29 (Message 11 to 15 of 15)
<<< Previous 10 Messages Goto Initial 15 Messages
Subject: Re: A note on #debug output in v3.7, beta 29
Date: 17 Dec 2008 07:29:40
Message: <4948f0b4$1@news.povray.org>
I'd suggest simply outputting whatever remains in the #debug message
buffer upon completion of the scene.  Doing so would match the
functionality that's in version 3.6.
Date: 17 Dec 2008 14:41:36
Message: <494955f0$1@news.povray.org>
That is already what 3.7 is supposed to do. I was not making the point that
the 3.7 behavior is intentional, just that a change to always output a
newline automatically is not desirable.
	Thorsten
Date: 17 Dec 2008 22:03:27
Message: <4803970500DD404DA341F4F68FC5A379@HomePC>
> -----Original Message-----
> From: Thorsten Froehlich [mailto:tho### [at] trfde]
> Chambers wrote:
> > It should be easy enough for POV to output a final newline at the
end
> of
> > all messages just to clean up things like this.
> Except that you frequently do not want automatic newlines: They
prevent
> assembly of longer outputs using multiple debug statements.
Read my message again:
"a final newline at the end of all messages"
If it makes it any clearer, you can say "a newline after all output
streams have been printed."  Or, to put it another way, after parsing
you flush the output stream buffers and then print a newline.
...Ben Chambers
www.pacificwebguy.com
Date: 19 Dec 2008 05:42:20
Message: <494b7a8c$1@news.povray.org>
	Yes, in case this is not yet the intended behavior in 3.7, I'd support
the idea that the debug buffer be forcefully flushed before the render starts
and not only at the end of the povray run.
	- NC
Date: 3 Jan 2009 05:50:16
Message: <495f42e8@news.povray.org>
Anyone have time to contribute a patch to do this?
-- Chris
