POV-Ray : Newsgroups : povray.beta-test : Media feature request Server Time
16 Feb 2026 22:32:38 EST (-0500)
  Media feature request (Message 1 to 4 of 4)
Subject: Media feature request
Date: 15 Sep 2008 00:24:22
Message: <48cde376@news.povray.org>
I don't know if you guys are taking requests in this forum or not. This
is something I would like to have appear in POV-Ray in the near future.
It would be nice if media could shadow the object it resides inside, and
for there to be a force_shadow keyword for media. Let's say I had a mesh
and I gave it a white pigment with zero brilliance, double_illuminate,
and a no_shadow keyword. I would add absorbing media with a force_shadow
keyword, and the result would be a reasonably fast subsurface scattering
effect.
Right now I'm having to make a copy of the mesh which is slightly fatter
than the original, and I'm getting strange artifacts resulting from
ior+media. I would simply use scattering and absorbing media for this
project, but it's impossible to reduce certain artifacts in thin
portions, short of adding a surface normal which would increase the
render time to new highs.
So, could this be done? To have an object with media shadow itself
(affecting the double_illuminate diffuse), and for there to be a
force_shadow keyword for media so that a shadowless object's media can
still cast a shadow?
Sam
Subject: Re: Media feature request
Date: 15 Sep 2008 12:00:00
Message: <web.48ce859d4250349439c0df820@news.povray.org>
> effect.
> Sam
I've read this a few times, and I am not sure I fully understand.  What it
sounds like you are describing is scattering media.  What is the difference
between what you are describing and scattering media?
I have used scattering and absorbing medias for SSS before.  What types of
artifacts are you getting?  Can you post the related code?
FYI, there is a forum for discussion of POV-ray 4, which is where most feature
requests are.
-Reactor
Date: 15 Sep 2008 18:04:09
Message: <48cedbd9@news.povray.org>
>> Sam
Using what I am proposing, the surfaces would not be transparent. Say
you had a plastic butter knife model. Using scattering media the usual
way, the blade edge would be transparent. This is good for some things,
but not others. In real life, objects have imperfections within and
without which help to (truly) scatter passing light, thus blurring an
image viewed through such a substance. In POV we can only blur the light
by using a surface normal on the object. It would be impractical to
actually blur light passing through an object, as this would render very
slowly. Therefore, it would be nice to simply keep the object opaque
while still achieving a SSS effect. (the effect would be much like my
recently-posted SSS code)
The features I propose would render faster than scattering media. I can
post examples and code if somebody is actually interested in
implementing it, and wants to understand how it should work.
Right near the side of the head near the eyelid, you can see straight
through to the eye! I could use really high scattering and absorption
settings, but new problems then arise. I could add a surface normal to
the head, which would be somewhat more realistic, but the render times
would skyrocket.
The code is too large to post, as it contains a mesh.
> requests are.
Why is the 3.x version still being updated, if not for improvement :)
Sam
Date: 15 Sep 2008 18:07:55
Message: <48cedcbb$1@news.povray.org>
> Reactor wrote:
> What is the difference between what you are describing and scattering media?
In other words, the object gets lighter and darker not because of
visible scattering media, but because its surface color is occluded by
absorbing media contained within it. The effect works very well in
conjunction with area_lights.
Sam
