POV-Ray : Newsgroups : povray.beta-test : benchmark Server Time
10 Oct 2025 12:43:09 EDT (-0400)
  benchmark (Message 1 to 7 of 7)
Subject: benchmark
Date: 11 Mar 2008 09:23:35
Message: <47d695e7@news.povray.org>
Just rendered a complex scene under 3.7 beta 25 64-bit
under Vista Ultimate 64-bit under Boot Camp on a Mac Pro, 16 GB, 8-core 3.0
machine.
Render Time: 6' 36"
the same scene on Win XP SP2,  Dell 2.2 GHz, 2 GB RAM:
3 hours 6 minutes!
best,
d
dhm### [at] comcastnet
http://www.dennismiller.neu.edu
Subject: Re: benchmark
Date: 11 Mar 2008 12:06:27
Message: <47d6bc13@news.povray.org>
> machine.
> Render Time: 6' 36"
> 3 hours 6 minutes!
  If my calculations are correct, that means that each core of the first
machine is over 3.5 faster than the processor in the Dell.
  Are you certain all the settings were identical? Maybe those cores *are*
that much faster, but...
  If everything is equal in both cases (including the resulting image),
then rather cool.
Date: 11 Mar 2008 14:47:07
Message: <slrn.ftdode.4l7.steev@hot.pl>
Don't underestimate the power of Warp...
>> 3 hours 6 minutes!
Maybe this Dell just ran out of RAM...?
Slawek
  ________
_/ __/ __/ Definitely. -- Dujour
 \__ \__ \_______________________________________________________________
Date: 11 Mar 2008 15:13:44
Message: <47d6e7f8$1@news.povray.org>
Warp nous apporta ses lumieres en ce 2008/03/11 13:06:
>> machine.
>> Render Time: 6' 36"
>> 3 hours 6 minutes!
> then rather cool.
If the slower machine ran out of RAM and started using the swap, then,that would
explain part of the difference.
A super machine with 64 cores available at 3 to 4 GHz, but only 1 GB of RAM can
be slower than a single core at 1 GHz with 16 GB...
Health is merely the slowest possible rate at which one can die.
Date: 11 Mar 2008 17:35:54
Message: <47d7094a@news.povray.org>
  If that's the case, the comparison is completely moot. It's not comparing
CPU processing power side-to-side.
Date: 11 Mar 2008 19:39:51
Message: <47d72657$1@news.povray.org>
Actually used the same ini file (1280 x 1024, AA 0.3)..
But I couldn't say if the Dell ran out of RAM... The scene is three
interlocked Julia fractals with some processor-intensive finishes
(reflection/refraction, et al).
Best,
d.
news:47d6bc13@news.povray.org...
>> 3.0
>> machine.
>> Render Time: 6' 36"
>> 3 hours 6 minutes!
> then rather cool.
>                                                          - Warp
Date: 13 Mar 2008 04:05:00
Message: <web.47d8ed6a2ce93b82b531ee70@news.povray.org>
For what it's worth, assuming no core-communications overhead (never a good idea
with multicore systems, but it makes things easier to figure) the 6min36sec on
the first system is roughly equivalent to 1h12min on the second system.
So yeah, it hit the swap pretty badly there (offhand, I'd guess the amount of
memory needed before it didn't hit swap at ~2.5GB, but that's just a
pulling-numbers-out-of-my-posterior guess, not a hard figure).
