POV-Ray : Newsgroups : povray.beta-test : 3.7 beta Unix/Linux source code now available. Server Time
9 Jun 2026 13:46:03 EDT (-0400)
  3.7 beta Unix/Linux source code now available. (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: 3.7 beta Unix/Linux source code now available.
Date: 28 Feb 2008 11:14:58
Message: <47c6de02@news.povray.org>
Thorsten Froehlich nous apporta ses lumieres en ce 2008/02/28 05:23:
> Warp wrote:
>> Thorsten Froehlich <tho### [at] trfde> wrote:
>>> This is not a bug, it is an internal buffer that trades speed for
>>> memory limits. It should not be needed, but a better solution is
>>> complicated and time intensive to implement.
>>   Could the reaching this limit be detected and a better error message be
>> shown?
> I said a better solution is possible, did I not? ;-)
>     Thorsten
The error message should read "Buffer overflow", not "Out of memory".
You know you've been raytracing too long when you can recite your high school
Trig book from memory.
Date: 28 Feb 2008 11:16:33
Message: <47c6de61$1@news.povray.org>
That will scare the hell out of users who know those two words related
to security vulnerabilities.
Date: 28 Feb 2008 11:54:25
Message: <47c6e741$1@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2008/02/28 11:16:
Undetected buffer overflow is bad. Detected ones or those that cause a process
to abort are usualy not a problem.
Alternately, it could be "Work buffer full", or "Buffer fault".
Date: 28 Feb 2008 12:00:31
Message: <47c6e8af$1@news.povray.org>
> process to abort are usualy not a problem.
It isn't a buffer overflow.
	Thorsten
Date: 28 Feb 2008 12:08:44
Message: <47c6ea9c@news.povray.org>
*I* know that, but go explain it to naive users, who have "buffer
overflow = security exploit" on their heads.
http://blogs.technet.com/markrussinovich/archive/2005/05/17/buffer-overflows.aspx
Also, the buffer didn't overflow. It reached a limit, and stopped there.
So such a message would be incorrect anyway.
Date: 28 Feb 2008 15:08:36
Message: <47c714c4$1@news.povray.org>
> "Timed out waiting for worker thread startup"
	This indeed seems to happen on Fedora 8 and some current gentoo distro
at least.  Others such as Debian or Ubuntu usually work.  At the moment
I can't tell what might cause the problem, i.e. whether it has to do with
libc, boost, the system thread library or else  :-/
	- NC
Date: 29 Feb 2008 10:55:37
Message: <47c82af9$1@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2008/02/28 12:08:
So "Buffer full" or "Buffer limit reatched" would be a more correct message.
Date: 29 Feb 2008 12:30:24
Message: <47c84130@news.povray.org>
  The message should also say *which* buffer. That way the user can know
better what exactly is it in his scene that is causing the problem.
Date: 1 Mar 2008 03:29:37
Message: <47c913f1$1@news.povray.org>
Le Thu, 28 Feb 2008 21:08:35 +0100, Nicolas Calimet a modifié des petits
morceaux de l'univers pour nous faire lire :
distro
> with libc, boost, the system thread library or else  :-/
> 	- NC
Yes. I confirm that.
I'm on gentoo amd64 (~amd64: unstable), and it looks like it can run once
then fails.
Even invoking only "povray --version" does produce this issue: first time
is ok, next are "Timed out".
My setting is
# ./configure COMPILED_BY=... --disable-io-restrictions
(... is a place holder)
# make check
# make install
Even adding --disable-optimiz-arch does not change the issue.
A reboot (it's a bit hard) allow one run.
I made a ps before first run, then after second (failed) run: no lagging
process.
The trigger seems to be in vfesession.cpp vfeSession::Initialize
Might it be related to a resume state ?
Shouldn't this issue have it's own thread ?
even the sequence:
# ./configure ....
# make check
# make check
would trigger the issue.
Any suggestion how I could help ?
Date: 1 Mar 2008 08:53:41
Message: <47c95fe5$1@news.povray.org>
it is great to have the code, I enjoy playing around with it ;)
With my self-compiled pov-ray beta I keep getting errors like "Xlib:
unexpected async reply (sequence 0x68)!". I suspect the reason is that
POV calls SDL functions from different threads or from signal handlers.
SDL's graphics functions are not thread-safe. I do not have this problem
when I switch the display off.
I have not tried the official binary.
Lukas
