POV-Ray : Newsgroups : povray.beta-test : Texture translation bug with Center_Trans() Server Time
10 Jun 2026 20:18:13 EDT (-0400)
  Texture translation bug with Center_Trans() (Message 1 to 7 of 7)
Subject: Texture translation bug with Center_Trans()
Date: 31 Jan 2008 01:57:14
Message: <47a1714a@news.povray.org>
I'm not sure how to describe what is happening, other than that objects
inside unions have their textures translated in odd ways by the
Center_Trans macro.
Consider this scene:
#include "transforms.inc"
	location -z*2
	look_at 0
#declare tube = union {
	cylinder {
		0, y, 1/10
			gradient y
			color_map {
				[0 color rgb x]
				[1 color rgb z]
object {tube Center_Trans(tube, x+y+z) rotate z*90 translate y/4}
object {tube rotate z*90 translate y*0.5+x*0.5}
#declare tube2 = cylinder {
	0, y, 1/10
		gradient y
		color_map {
			[0 color rgb y]
			[1 color rgb 1]
object {tube2 Center_Trans(tube2, x+y+z) rotate z*90 translate -y/4}
object {tube2 rotate z*90 translate -y*0.5+x*0.5}
light_source {
	<1,1,-1>*10 color rgb 1
Rendered in 3.6, both pairs of tubes are identical.
Rendered in 3.7, we can see that the upper tube's texture is translate
wrt it's pair's texture, despite them being identical objects.  The only
difference is that the one object is translated via Center_Trans(),
while the other is not.
The second pair of tubes, in which the cylinder itself is the object
(rather than being contained inside a union), does not exhibit this bug.
This leads me to believe that the problem is the combination of
Center_Trans(), unions, and textures.  But I'm not sure why, or exactly how.
Sorry I couldn't give more detailed info, but this one was quite tricky
for me to track down.
...Ben Chambers
www.pacificwebguy.com
Subject: Re: Texture translation bug with Center_Trans()
Date: 1 Feb 2008 22:00:21
Message: <47a3dcc5$1@news.povray.org>
Was anybody able to at least reproduce this bug on their system?
...Ben Chambers
Date: 3 Feb 2008 17:10:00
Message: <web.47a63b281751335e7d55e4a40@news.povray.org>
> ...Ben Chambers
Yes, although beta 24 has now expired. I noticed a possibly similar problem last
week with patterns used in media densities appearing to be translated
incorrectly when their parent object was transformed with a Shear_Trans or
Matrix_Trans call, but I was unable to reduce it to a minimal scene.
Tom
Date: 4 Feb 2008 03:19:11
Message: <47a6ca7f$1@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> schreef in bericht
news:47a3dcc5$1@news.povray.org...
Yes, I got the same results
(Windows XP)
Date: 5 Feb 2008 06:24:17
Message: <47a84761$1@news.povray.org>
> (Windows XP)
Me too, in beta 25, and verified it works fine in 3.6.
I think it has to do with the use of transform{}. Here's
a modified scene that removes "transforms.inc" from
the minimal scene.
   location <0,1,-4>
   look_at <0,0,0>
   angle 30
light_source {
// inside a union
   cylinder {
      <0,0,0>, <0,1,0>, 0.1
         gradient y
         color_map {
            [0 color <1,0,0>] // red
            [1 color <0,0,1>] // blue
// just a cylinder
   0, y, 1/10
      gradient y
      color_map {
         [0 color <0,1,0>] // green
         [1 color <1,1,1>] // white
// with object in union, red-blue
object {
   tube
   transform {translate <0.25,-0.5,0>}// this transform misaligns texture
object {
   tube
   translate <-0.25,-0.5,0>
// with cylinder only, green-white
object {
   tube2
   transform {translate <0.5,-0.5,0>}// this tranform works fine
object {
   tube2
   translate <-0.55,-0.5,0>
Date: 22 Feb 2008 20:55:01
Message: <web.47bf7c091751335e7d55e4a40@news.povray.org>
There doesn't seem to be any way yet to feed back proposed fixes for defects
except through the newsgroups, so:
I think I've found the problem using a minor simplification of Tim's scene and
the recently released Beta 3.7 source. In csg.cpp#40, in the 3.7.beta.25b
source archive, CSG::Transform is defined as:
void CSG::Transform(TRANSFORM *tr)
  for(vector<ObjectPtr>::iterator Current_Sib = children.begin(); Current_Sib !=
children.end(); Current_Sib++)
    (*Current_Sib)->Transform(tr);
  Recompute_BBox(&BBox, tr);
This is only called when you use a transform {} block with a CSG object.
Changing
to
Transform_Object (*Current_Sib, tr);
seems to fix the problem, because the former only sets up the transforms on the
child geometry (a cylinder in this case) whereas Transform_Object calls the
needful transformations on the textures as well (and some other stuff). The
latter also looks more like the implementation of CSG::Translate, CSG::Rotate
and CSG::Scale (which are called to handle your transforms when you don't use a
transform block).
For reference, the final minimal scene is included below. Both the red->blue
texture and the black->white texture should appear as smooth vertical gradients
following the fix. I can't guarantee that this fix does not cause unintended
regressions.
   location <0,1,-4>
   look_at <0,0,0>
   angle 30
light_source {
union {
   cylinder {
         gradient y
         color_map {
            [0 color <1,0,0>]
            [1 color <0,0,1>]
union {
   cylinder {
         gradient y
         color_map {
            [0 color <0,0,0>]
            [1 color <1,1,1>]
   translate <-0.25,-0.5,0>// this transform doesn't misalign texture
Date: 22 Feb 2008 21:25:00
Message: <web.47bf82cc1751335e7d55e4a40@news.povray.org>
The proposed fix also seems to address the defect mentioned by Tim and
elaborated on by Samuel Benge in the bugs list for beta 25:
http://news.povray.org/povray.beta-test/thread/%3C47a84bb1%241%40news.povray.org%3E/
The results were checked using the minimal scene provided there.
The Transform_Object routine takes care of transforming objects used in
clipped_by, so calling it would believably fix clipped_by transform {} problems
too.
