Subject: Re: Beta 24 Linux x86_64 on Ubuntu 7.10 : X server error
Date: 14 Jan 2008 11:55:56
Message: <478b941c$1@news.povray.org>
> Do you also get a transparent preview window on Ubuntu?
Do you happen to use a compositing window manager a la Beryl?
The display preview hasn't be tested in this environment yet.
- NC
Date: 14 Jan 2008 12:08:37
Message: <478b9715@news.povray.org>
> XIO: fatal IO error 0 (Success) on X server ":0.0"
> after 32 requests (29 known processed) with 1 events remaining.
Yes, I got it sometimes too... Another X11-related error might happen as well
(Xsync problem IIRC) and sadly requires to SIGKILL (kill -9) the process. As long as
we'll be using the SDL library for preview display there won't be much to do about it
unfortunately.
- NC
yes. It's becoming pretty common and Ubuntu 7.10 readily recognized my nvidia
and offered to download and install the nvidia driver and get ahead with wheezy
graphics effects...
Date: 14 Jan 2008 13:17:59
Message: <478ba756@news.povray.org>
> As long as
it
> unfortunately.
How about not using the SDL library? 3.6 didn't need it.
> > As long as
it
> > unfortunately.
oh! Only now I saw you guys are talking about 3.7 beta.
well, it works the same with 3.6, warp. That was what I was complaining... so,
it isn't the SDL lib, I guess... can it be related to png transparency?
Subject: Transparency problem (Was: Re: Beta 24 Linux x86_64 on Ubuntu 7.10 : X server error)
Date: 14 Jan 2008 14:25:08
Message: <478bb714$1@news.povray.org>
nemesis wrote:
> hey, Jaime! Do you also get a transparent preview window on Ubuntu? It's
> almost impossible to see anything. I just turn it off and get previews from
> the file manager. Unfortunately, I can't get previews of radiosity during the
> pretrace stage that way...
No, I don't have the transparency problem because I use WIndowMaker, but
still it shows garbage instead. The "solution" was posted some weeks ago (I
don't remember who was the poster), and it is to use the visual option to
select a different color mode:
povray ... -visual DirectColor
DirectColor works for me, but YMMV...
Jaime
oh. I used to use WindowMaker in my early Linux years. Then I got bored and
decided to get more of a 2000's feel and hog resources with Gnome.
this is a great tip, thanks...
it's not like I can't simply shut down Compiz, though...
wow! many thanks! It really works without a problem!
Date: 15 Jan 2008 07:23:58
Message: <478ca5de$1@news.povray.org>
There will be a plain X11 replacement at some point.
- NC
Date: 15 Jan 2008 07:26:21
Message: <478ca66d$1@news.povray.org>
Yes, 3.6 (and likely any previous version that implements the
X11 display preview) has problems with compositing WMs. This has been
fixed some time ago for the next 3.6.2 release -- which unfortunately
is still in hold.
- NC
