POV-Ray : Newsgroups : povray.beta-test : Full area lighting in next beta Server Time
14 Jul 2026 19:27:54 EDT (-0400)
  Full area lighting in next beta (Message 21 to 30 of 42)
Subject: Re: Full area lighting in next beta
Date: 6 Nov 2007 05:26:26
Message: <47304152@news.povray.org>
47302c02@news.povray.org...
> Usually you want to be able to control color mapping after the render.
Theoretically yes, but when color mapping is an integral part of the image's
aesthetics, it's often more practical to have it done at render time, rather
than having to open the image in Photoshop and change it each time with the
same settings. It's not uncommon to create scenes that depend heavily on
color mapping to look right and having to correct them at each iteration of
the creation process would considerably slow down the workflow. I guess
that's the reason why the feature is included in most (if not all) high-end
renderers.
G.
Date: 6 Nov 2007 05:34:04
Message: <4730431c$1@news.povray.org>
472fbce7@news.povray.org...
> Gilles Tran <gitran_nospam_@wanadoo.fr> wrote:
>> A very useful feature that goes hand in hand with full area lights is
>> color
>> mapping aka tone mapping aka exposure control.
>  I didn't quite get the idea from those images. Some text explaining in
> simple terms the idea and the algorithm could be useful.
In addition to Thorsten's links, here's an explanation about how it's done
in Mental Ray :
http://toi.bk.tudelft.nl/toi-pedia/index.php?title=Rendering_Mental_Ray:_Tone_mapping
G.
Date: 6 Nov 2007 07:33:54
Message: <47305f32@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> MegaPOV gives you the
> option of defining any tone mapping function although this currently is
> limited to  a 1D function identical for all color channels.  It might be
> interesting to make this a more general feature allowing full control
> over the mapping in all three color channels
  Since POV-Ray supports user-defined vector functions, it might be possible
to do it like that.
Date: 6 Nov 2007 08:33:48
Message: <47306d3c@news.povray.org>
> in Mental Ray :
  Am I understanding correctly that "tone mapping" is nothing else than
a function which takes one parameter, namely a brightness value (eg. of a
color channel), and returns a brigthness value (usually the input value
multiplied by some function)?
  Could it also be a function taking three parameters, namely the red,
green and blue components of the color, and returning a vector?
Date: 6 Nov 2007 12:49:22
Message: <4730a922$1@news.povray.org>
>> in Mental Ray :
No, it can be much more complex than that. Go "Up" twice on the page whose
link I posted. It is actually from a dissertation discussing various
functions, some of which require more than a handful of parameters.
	Thorsten
Date: 6 Nov 2007 12:52:10
Message: <4730a9ca@news.povray.org>
  Could someone write a short summary?
  If it's not just a (user-defined) function which takes certain parameters
and returns a value/color, then what is it?
Date: 6 Nov 2007 13:15:52
Message: <Xns99E0C3E6CB3A0seed7@news.povray.org>
Yes, but often you don't want to do it in a separate step/application. But
if I'm not mistaken, gamma correction is now a kind of "postprocessing
step". Isn't this the same place where tonemapping, colur managent,
colourspace conversions  etc. should be done.
Such a setup would mean that tonemapping functions (or gamma-curves) won't
be specified in the scene itself but in a "postprocessing-ini-file".
Ingo
Date: 6 Nov 2007 13:56:44
Message: <4730b8ec$1@news.povray.org>
A algorithm with up to n**2 complexity per pixel afaict (wthout checking in
detail) from some of the existing algorithms.
	Thorsten
Date: 6 Nov 2007 14:37:43
Message: <4730c287$1@news.povray.org>
Warp nous apporta ses lumieres en ce 2007/11/05 22:19:
> Trevor G Quayle <Tin### [at] hotmailcom> wrote:
>> 1) System variables to return the resolution of an input image.  This appears to
>> be already available in the source code, just not passed on to the SDL.
>   This should definitely be doable, but I'll have to ask the team about
> their opinion. (Cons: Minor feature, increases reserved keyword clutter...)
We already have image_width and image_height, why not reuse it with this
variation: when included with an image that is loaded, it returns the dimentions
of that image instead of that of the rendered image.
It could look somewhat like:
image_map{jpg "MyImage.jpg" Width = image_width, Height = image_hight, [your
other parameters]}
You know you've been raytracing too long when you can no longer tell the
difference between the top raytracing book and the "Raytracing for Dummies"
book. To you, they're both hopelessly uninformed.
     -- Taps a.k.a. Tapio Vocadlo
Date: 6 Nov 2007 16:10:00
Message: <web.4730d7351489f6c8c150d4c10@news.povray.org>
> other parameters]}
Unfortuneately image_map can't be declared explicitly like:
#declare A=image_map{jpg "MyImage.jpg"} so using it this way would require it to
be applied to something (mind you it could be just a dummy pigment, but this
seems un-neat to me).
I would see it working more similar to min_extent/max_extent maybe:
#declare A=resolution{jpg "MyImage.jpg"};
or perhaps min_extent/max_extent could be reused to avoid adding a new
keyword(in this case min_extent would always be <0,0> or it could be just left
out)
-tgq
