POV-Ray : Newsgroups : povray.beta-test : Full area lighting in next beta Server Time
22 Dec 2025 16:52:09 EST (-0500)
  Full area lighting in next beta (Message 3 to 12 of 42)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Full area lighting in next beta
Date: 3 Nov 2007 21:55:01
Message: <web.472d34071489f6c88669fa170@news.povray.org>
That's wonderful news!  looks definetely realistic!
all hail Warp! :D
Date: 3 Nov 2007 23:25:54
Message: <472d49d2$1@news.povray.org>
Warp nous apporta ses lumieres en ce 2007/11/03 18:57:
>   I added one long-requested feature to the codebase, namely support for
> area-light diffuse and specular lighting. This means that with a switch
> you can make area lights not only affects shadows but also illumination.
> The result will be the same as when using an explicit grid of point light
> sources, but faster.
>   At least for now the full illumination will by default be off (so it
> will work as currently), but it can be turned on with a new keyword inside
> the light_source definition block.
>   Example:
>   This is an image rendered with a regular old area_light (rendered with
> "-w800 -h600 +a0.1 +am2"):
> http://warp.povusers.org/images/arealighttest1.jpg
>   It took 13 seconds to render in my computer.
>   This is the same scene, but the area light has been replaced with the
> equivalent grid of point lights:
> http://warp.povusers.org/images/arealighttest2.jpg
>   This took 1 min 51 seconds to render.
>   This is, again, the area_light, but with the new full area lighting
> feature turned on:
> http://warp.povusers.org/images/arealighttest3.jpg
>   This took 36 seconds to render.
>   As always, new features are experimental and thus will require extensive
> testing.
Looks very promising.
Waiting for the chance of testing it.
Grabel's Law: 2 is not equal to 3 -- not even for large values of 2.
Date: 5 Nov 2007 03:23:59
Message: <472ed31f@news.povray.org>
That looks very good indeed! Thanks Warp!
Date: 5 Nov 2007 05:10:00
Message: <web.472eebc41489f6c8e8ba46670@news.povray.org>
Wondeful! Thanks Warp!
    Bruno
Date: 5 Nov 2007 15:00:00
Message: <web.472f75f41489f6c82d65e3b10@news.povray.org>
Oooohh, new toy. Thanks!
Date: 5 Nov 2007 15:06:44
Message: <472f77d4@news.povray.org>
Good work.
Especially the "reflection" on the table surface looks dramatically more
realistic with correct lighting. It's all good!
Now if you could also add feature XYZ as well... ;-)
Date: 5 Nov 2007 15:35:22
Message: <472f7e8a@news.povray.org>
  If it's not something which will require me to work for a week
10 hours a day, or something which will require a rewrite of the
parser, I'mlistening.
Date: 5 Nov 2007 15:42:07
Message: <472f801f$1@news.povray.org>
Well... how hard would it be to make is so that if you use a normal
object with a nonzero "ambient" setting to make a "light source" in
radiosity mode, you get specular hilights?
[Wait, is radiosity working in the beta yet? *checks release notes*]
Date: 5 Nov 2007 16:04:48
Message: <472f8570@news.povray.org>
  Add a reflection and a proper reflection exponent to the object.
To blur the reflection, use the blurred reflection trick.
Date: 5 Nov 2007 16:45:23
Message: <472f8ef3$1@news.povray.org>
472f7e8a@news.povray.org...
A very useful feature that goes hand in hand with full area lights is color
mapping aka tone mapping aka exposure control. There's already some code for
it in Megapov. Basically one needs 3 modes : linear, exponential and HSV
(plus gamma correction and some others).
http://www.vray.us/vray_documentation/vray_color_mapping_examples.shtml
This is for Vray but it's standard in other renderers. The examples above
are not very impressive, but HSV color mapping, particularly, is a must have
for interior scenes.
G.
