![](/i/fill.gif) |
Nicolas Calimet wrote:
>> This Version crashes immediatly after start.
> Can't reproduce this with slightly older kernels (2.6.18 and .19 here).
> Could you please run 'strace ./povray --version' from the package
> directory
> and report the result? (You may also try the povray-gcc binary instead.)
> Thanks for testing,
> - NC
Hello !
Here is the output:
execve("./povray", ["./povray", "--version"], [/* 87 vars */]) = 0
uname({sys="Linux", node="Fortress", ...}) = 0
brk(0) = 0x88db000
brk(0x88dbce0) = 0x88dbce0
set_thread_area({entry_number:-1 -> 6, base_addr:0x88db860, limit:1048575,
seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1,
seg_not_present:0, useable:1}) = 0
set_tid_address(0x88db8a8) = 14433
SYS_311(0x88db8b0, 0xc, 0x88db860, 0x20616, 0x3) = 0
rt_sigaction(SIGRTMIN, {0x84097c0, [], SA_SIGINFO}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x84096f0, [], SA_RESTART|SA_SIGINFO}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(0x88fcce0) = 0x88fcce0
brk(0x88fd000) = 0x88fd000
futex(0x887f1bc, FUTEX_WAKE, 2147483647) = 0
futex(0x8854570, FUTEX_WAKE, 2147483647) = 0
futex(0x8854568, FUTEX_WAKE, 2147483647) = 0
mmap2(NULL, 266240, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0)
= 0xb7fbc000
= 0xb7f7b000
time(NULL) = 1185168033
write(2, "povray: this pre-release version"..., 89povray: this pre-release
version of POV-Ray for Unix expires in 22 day(s) and 16 hour(s)
) = 89
rt_sigprocmask(SIG_BLOCK, ~[RTMIN RT_1], NULL, 8) = 0
mmap2(NULL, 8388608, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE
MAP_ANONYMOUS, -1, 0) = 0xb777b000
mprotect(0xb777b000, 4096, PROT_NONE) = 0
clone(child_stack=0xb7f7a314, flags=CLONE_VM|CLONE_FS|CLONE_FILES
CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID
CLONE_CHILD_CLEARTID|CLONE_DETACHED, parent_tidptr=0xb7f7abd8,
{entry_number:6, base_addr:0xb7f7ab90, limit:1048575, seg_32bit:1,
contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0,
useable:1}, child_tidptr=0xb7f7abd8) = 14434
futex(0xbfbdcd80, FUTEX_WAIT, 1, NULL) = 0
futex(0xbfbdcd5c, FUTEX_WAIT, 2, NULL) = 0
futex(0xbfbdcd5c, FUTEX_WAKE, 1) = 0
open("/usr/local/etc/povray/3.7/povray.conf", O_RDONLY|O_LARGEFILE) = 3
read(3, ";;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;"..., 8191) = 4267
readlink("/usr", 0x88e0cd0, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local", 0x88e0ca8, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local/share", 0x88e0ca8, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local/share/povray-3.7", 0x88e0ca8, 255) = -1 EINVAL (Invalid
argument)
readlink("/usr/local/share/povray-3.7/include", 0x88e0ca8, 255) = -1 EINVAL
(Invalid argument)
readlink("/usr", 0x88e0d08, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local", 0x88e0ce0, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local/share", 0x88e0ce0, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local/share/povray-3.7", 0x88e0ce0, 255) = -1 EINVAL (Invalid
argument)
readlink("/usr/local/share/povray-3.7/scenes", 0x88e0ce0, 255) = -1 EINVAL
(Invalid argument)
readlink("/usr", 0x88e0d50, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local", 0x88e0d28, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local/share", 0x88e0d28, 255) = -1 EINVAL (Invalid argument)
readlink("/usr/local/share/povray-3.7", 0x88e0d28, 255) = -1 EINVAL (Invalid
argument)
readlink("/usr/local/share/povray-3.7/..", 0x88e0d28, 255) = -1 EINVAL
(Invalid argument)
readlink("/usr/local/share/povray-3.7/../..", 0x88e0d28, 255) = -1 EINVAL
(Invalid argument)
readlink("/usr/local/share/povray-3.7/../../etc", 0x88e0d28, 255) = -1
readlink("/home", 0x88e0d28, 255) = -1 EINVAL (Invalid argument)
readlink("/home/thomas", 0x88e0d28, 255) = -1 EINVAL (Invalid argument)
readlink("/tmp", 0x88e0d28, 255) = -1 EINVAL (Invalid argument)
getcwd("/home/thomas/pov_beta_temp/povray-3.7.0-linux-2.6-x86", 256) = 54
readlink("/home", 0x88e0e78, 255) = -1 EINVAL (Invalid argument)
readlink("/home/thomas", 0x88e0e78, 255) = -1 EINVAL (Invalid argument)
readlink("/home/thomas/pov_beta_temp", 0x88e0da0, 255) = -1 EINVAL (Invalid
argument)
readlink("/home/thomas/pov_beta_temp/povray-3.7.0-linux-2.6-x86", 0x88e0da0,
read(3, "", 8191) = 0
close(3) = 0
open("/home/thomas/.povray/3.7/povray.conf", O_RDONLY|O_LARGEFILE) = 3
read(3, ";;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;"..., 8191) = 4266
argument)
(Invalid argument)
argument)
(Invalid argument)
argument)
(Invalid argument)
(Invalid argument)
argument)
close(3) = 0
gettimeofday({1185168033, 219824}, NULL) = 0
MAP_ANONYMOUS, -1, 0) = 0xb6f7b000
mprotect(0xb6f7b000, 4096, PROT_NONE) = 0
clone(child_stack=0xb777a314, flags=CLONE_VM|CLONE_FS|CLONE_FILES
CLONE_CHILD_CLEARTID|CLONE_DETACHED, parent_tidptr=0xb777abd8,
{entry_number:6, base_addr:0xb777ab90, limit:1048575, seg_32bit:1,
useable:1}, child_tidptr=0xb777abd8) = 14435
futex(0xbfbdcd24, FUTEX_WAIT, 1, NULL) = 0
futex(0xbfbdcd00, FUTEX_WAIT, 2, NULL) = 0
futex(0xbfbdcd00, FUTEX_WAKE, 1) = 0
clock_gettime(CLOCK_REALTIME, {1185168033, 220012323}) = 0
futex(0x88ddd84, FUTEX_WAIT, 1, {2, 779987677}) = 0
clock_gettime(CLOCK_REALTIME, {1185168033, 274422655}) = 0
futex(0x88ddd60, FUTEX_WAKE, 1) = 0
futex(0xb777abd8, FUTEX_WAIT, 14435, NULL) = 0
write(2, "POV-Ray 3.7.0.beta.21a\n\nThis is "..., 224POV-Ray 3.7.0.beta.21a
This is a time-limited beta test version. No re-distribution
of any sort is permitted.
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2007 Persistence of Vision Raytracer Pty. Ltd.
) = 224
write(2, "Built-in features:\n I/O restric"..., 238Built-in features:
I/O restrictions: enabled
X Window display: enabled
SVGAlib display: disabled
Supported image formats: gif tga iff ppm pgm hdr png jpeg tiff openexr
Unsupported image formats: -
) = 238
write(2, "Compilation settings:\n Build ar"..., 310Compilation settings:
Build architecture: i686-pc-linux-gnu
Built/Optimized for: i686-pc-linux-gnu
Compiler vendor: intel
Compiler version: icpc 10.0
Compiler
flags: -pipe -Wno-multichar -s -O3 -ip -no-prec-div -malign-double -funroll-loops
-fomit-frame-pointer -axKWNPT -mtune=pentium4
) = 310
munmap(0xb7f7b000, 266240) = 0
munmap(0xb7fbc000, 266240) = 0
exit_group(0) = ?
Process 14433 detached
Greetings
Thomas Debe
![](/i/fill.gif) |
