POV-Ray : Newsgroups : povray.beta-test : No String Parameters for Macros? Server Time
29 Sep 2024 13:24:02 EDT (-0400)
  No String Parameters for Macros? (Message 1 to 7 of 7)
Subject: No String Parameters for Macros?
Date: 16 Nov 2006 07:01:39
Message: <455c5323$1@news.povray.org>
I had a problem with my macro: it seems, macros don't accept string
parameters, only numerical values. Is that true?
I am using the latest beta version. (By mistake, I posted this thread in
another section, sorry.)
Greetings,
Sven
Subject: Re: No String Parameters for Macros?
Date: 16 Nov 2006 07:24:54
Message: <455c5896$1@news.povray.org>
	Please provide a minimal test scene.
	Why not canceling a message you just posted?  Doesn't MS OE support
that feature?
	- NC
Date: 16 Nov 2006 07:37:23
Message: <455c5b83$1@news.povray.org>
True, I should have added the sample code. Here is the macro:
#macro Exit(Sign,SignWhere,Angle,Rotation,Translation)
 union
  difference
   union
    cylinder // Round Wall
     < -0.025, 0.0, 0.0 > < 0.025, 0.0, 0.0 > 1.20
     pigment
      gradient y
      pigment_map
       [ 0.0 rgb < 0.3137255, 0.3882353, 0.5607843 > ]
       [ 0.3 rgb < 0.3137255, 0.3882353, 0.5607843 > ]
       [ 0.3 White ]
       [ 1.0 White ]
      scale 2.40
      translate < 0.0, -1.20, 0.0 >
    box // Door Frame
     < -0.035, -1.05, -0.55 > < 0.035, 1.05, 0.55 >
     pigment { Black }
   box // Door Cut-Out
    < -0.036, -1.0, -0.5 > < 0.036, 1.0, 0.5 >
    pigment { Black }
  union
   difference
    box // Door
     < -0.055, -1.0, -0.5 > < 0.055, 1.0, 0.5 >
     pigment { White }
    cylinder // Window Cut-Out
     < -0.056, 0.4, 0.0 > < 0.056, 0.4, 0.0 > 0.10
     pigment { Black }
   torus
    0.10, 0.025
    pigment { rgb < 0.9960784,  0.7686275,  0.2392157 > }
    translate < 0.0, 0.0, 0.30 >
   #if(Sign!="")
HERE IS THE ERROR
    #if(SignWhere="A")
     box { < -0.000, 0.6, -0.20 > < 0.056, 0.8, 0.20 > pigment { Black }
rotate < 0.0, 000.0, 0.0 > }
    #if(SignWhere="B")
rotate < 0.0, 180.0, 0.0 > }
   #if(Angle>90.0)
    #declare Angle=90.0;
   #if(Angle<-90.0)
    #declare Angle=-90.0;
   translate < 0.0, 0.0, 0.5 >
   rotate < 0.0, Angle, 0.0 >
   translate < 0.0, 0.0, -0.5 >
  rotate Rotation
  translate Translation
And here is the call to that macro:
 Exit("A",0,+70,< 0.0, 090.0, 0.0 >,< -0.0, 1.5, 3.85 >)  // Exits
This causes the error message "Numerical value expected but string value
found" (something like that).
Sven
Date: 16 Nov 2006 08:45:00
Message: <web.455c6ad6102a121ac150d4c10@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote:
>    #if(Sign!="")
The problem is not the macro.  It's that #if expects numericals and does not
accept strings.  Try using the strcmp() function which compares strings:
   #if (strcmp(Sign,"")!=0)  //TRUE if (Sign != ""), strcmp()returns 0 if
both strings are equal
>     #if(SignWhere="A")
>     #if(SignWhere="B")
You're also going to have to fix this.  You pass a number for SignWhere, but
try to use it as a string.  Choose which you want and modify accordingly.
-tgq
Date: 16 Nov 2006 13:22:12
Message: <455cac54@news.povray.org>
Trevor,
thanks a lot! Your hint works for me.
Greetings,
Sven
Date: 16 Nov 2006 17:01:49
Message: <455cdfcd@news.povray.org>
> accept strings.
  A shortcoming which, IMO, should be fixed. I see absolutely no reason
for strings not supporting the comparison operators.
Date: 30 Nov 2008 19:58:13
Message: <493336a5@news.povray.org>
>> not accept strings.
For the benefit of people reading old threads: this was added in
3.7.beta.23.
 "Added comparison ('=', '!=', '<', '<=', '>', '>=') support for strings."
