POV-Ray : Newsgroups : povray.beta-test : PovRay 3.7.0beta.12a Server Time
16 May 2026 10:17:25 EDT (-0400)
  PovRay 3.7.0beta.12a (Message 1 to 4 of 4)
Subject: PovRay 3.7.0beta.12a
Date: 14 Apr 2006 23:37:41
Message: <44406a85@news.povray.org>
I've tried the 12a beta today, most of my renders come out as expected,
however, scenes imported from Daz via PoseRay regardless of settings or ini
file just sits after the parse, I checked the processor load and memory
during several of the tests. Processor load goes back down to 50% and memory
used down to 300MB immediatly after parse (it will incline close to 900MB on
most of my more complex scenes) instead of staying high until end of render.
Theories anyone? BTW 3.6 has no trouble rendering the scenes, just takes
twice as long (single thread) Once I find my copy of Blender I'll try
importing an OBJ from it instead to see if there is a difference. I did run
the scenes that I knew had meshes in them as well as running that grass
macro (uses a mesh) from the Gilles cloud tutorial with a few million blades
to see if there was too many triangles.
Thanks in advance,
Jonathan
red### [at] redmasqcom
AMD 64 Dual Core 1GB RAM Windows XP Home
    (Shame I don't have the 64bit version or better
    yet find where I put that Slackware disc, though of course I'd have to
run two instances of 3.6)
PovRay 3.7.0.beta.12a
PovRay 3.6.1a.icl8.win32
PoseRay 3.8.18.390
Subject: Re: PovRay 3.7.0beta.12a
Date: 15 Apr 2006 08:15:31
Message: <4440e3e3@news.povray.org>
"Jonathan" <red### [at] redmasqcom> wrote in message
news:44406a85@news.povray.org...
> Thanks in advance,
> Jonathan
> PoseRay 3.8.18.390
Are you running with +B2?  If so turn it off and then try.  Also try running it
with /THREADS 1 and see if it renders then.  See if any combinations work and
post back with the results to help narrow it down :)
Lance.
thezone - thezone.firewave.com.au
Date: 15 Apr 2006 19:41:21
Message: <444184a1@news.povray.org>
> running it
> and
> Lance.
Wasn't running with +B2, tried with /THREADS 1 same result. For the heck of
it tried it with +B2 same thing.
Thanks,
Jonathan
Date: 21 Apr 2006 23:04:26
Message: <44499d3a@news.povray.org>
Update:
I managed to get a copy of blender and imported the mesh and reexported the
mesh back into PoseRay and rendered. Worked fine expect for my losing all my
groups and UV mappngs. I assume the next course would be to break up the
groups before exporting and recombine and map in poseray to see if the
problem repeats itself. Assuming that it would provide ANY valuable data at
all.
Thanks,
Jonathan
