POV-Ray : Newsgroups : povray.beta-test : Parser Statistics, empty ini Server Time
11 Jun 2026 00:18:04 EDT (-0400)
  Parser Statistics, empty ini (Message 1 to 6 of 6)
Subject: Parser Statistics, empty ini
Date: 31 Mar 2006 22:22:02
Message: <442df1da$1@news.povray.org>
If I have a scene with fewer objects than the Bounding_Threshold, I get the
following stats.
Finite Objects are not counted.
Infinite Objects are counted under Finite Objects
Light Sources are counted under both Light Sources and Finite objects
If I equal or exceed the Bounding_Threshold all is well.
If I try to render an empty ".ini" file. WinPOV tells me "No source file
specified..." (correct) but the Run icon remains as the Stop icon. Pointing
WinPOV to a valid file and clicking the (now) Stop icon runs the file.
Clicking on the menu " file/exit" does nothing, using "alt+x" or the "close"
button in the upper right hand corner correctly exits WinPOV.
Subject: Re: Parser Statistics, empty ini
Date: 31 Mar 2006 22:24:46
Message: <442df27e$1@news.povray.org>
If I render the same file several times, sometimes large numbers appear
under Infinite Objects.
Date: 31 Mar 2006 22:31:21
Message: <442df409$1@news.povray.org>
Oops, Win98se AMD Athlon 2200+ 256mb
3.7.0.beta.12a.icl8.win32
Subject: WinPOV editor, invalid page fault
Date: 2 Apr 2006 16:48:06
Message: <44303886$1@news.povray.org>
The following sequence gives me an 'invalid page fault' in POVCMAX32.DLL
80% of the time. WinPOV shuts down losing any unsaved work.
Select any file
left-click-hold-drag to highlight text
While still holding the left mouse button, right-click(menu pops up)
Release left mouse button
Move mouse to highlight more text
left-click
3.6.1 same problem
3.5 reports 'External exception C000001D', WinPOV still works.
Subject: Re: WinPOV editor, invalid page fault
Date: 2 Apr 2006 20:24:42
Message: <44306b4a@news.povray.org>
> Select any file
> left-click
thanks for the accurate report! I was able to reproduce this straight away.
will be fixed.
-- Chris
Date: 1 May 2006 07:49:52
Message: <4455f5e0$1@news.povray.org>
> following stats.
fixed.
fixed.
aaaand fixed.
Thanks for the reports!
-- Chris
