POV-Ray : Newsgroups : povray.beta-test : [animation] Initial_Frame=0 begins with 1 instead Server Time
11 Jun 2026 00:17:24 EDT (-0400)
  [animation] Initial_Frame=0 begins with 1 instead (Message 1 to 8 of 8)
Subject: [animation] Initial_Frame=0 begins with 1 instead
Date: 22 Feb 2006 08:31:13
Message: <43fc67a1$1@news.povray.org>
Using INI file for animation and setting Initial_Frame=0 ignores the zero,
starting the series of file names at frame 1. Same happens with command-line
switch +kfi0
When I tried Subset_Start_Frame=0 the program crashed.
3.7.0.beta.11c.icl8.win32
Subject: Re: [animation] Initial_Frame=0 begins with 1 instead
Date: 22 Feb 2006 08:49:10
Message: <43fc6bd6$1@news.povray.org>
> switch +kfi0
The smallest allowed initial frame value is 1.
Indeed, POV-Ray should not crash when facing invalid input :-)
	Thorsten
Date: 22 Feb 2006 09:10:21
Message: <43fc70cd$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:43fc6bd6$1@news.povray.org...
>> zero, starting the series of file names at frame 1. Same happens with
>> command-line switch +kfi0
Well, good you said that, program crashing problem will likely get fixed
then. heh-heh
However, since initial frame of zero is unavailable, this must mean
something was changed. I had mostly used that as the starting number for
mpeg creation by running a batch file which accepts a number of digits at
the end of a file name, anim000 for example, and counts up from there. It
can be worked around, of course. Makes me wonder, though, why it must be 1
and not 0 anymore. Was there a special reason involved or was it about ways
people expect counting to begin?
Bob H
Date: 22 Feb 2006 09:30:45
Message: <43fc7595$1@news.povray.org>
> then. heh-heh
It was actually never documented to work, and as such never checked if it
does work. It is possible that previous versions did work with 0 (certainly
no negative values) for the most part, but I certainly would not want to
claim the results were predictable for all animation features (i.e. field
rendering, subframe rendering, etc).
	Thorsten
Date: 22 Feb 2006 09:46:45
Message: <43fc7955@news.povray.org>
news:43fc7595$1@news.povray.org...
I never gave it a second thought, myself, since counting from zero seems to
go along with things like 0 to 1 to maybe mirror the clock's (decimal)
values. Just thought 1,2,3... might have been determined to be more common
and therefore less confusing for frame counts, but then POV is often
considered to have been made to allow for out of the ordinary user-specified
numbers so negative frame numbers wouldn't be too surprising either.  ;)
Bob H
Date: 22 Feb 2006 10:10:54
Message: <43fc7efe$1@news.povray.org>
"Bob Hughes" <omniverse@charter%net> wrote in message
news:43fc7955@news.povray.org...
Indeed 0 is what 3D Studio MAX uses as its first frame (but it has always made
things difficult).
Lance.
thezone - thezone.firewave.com.au
Date: 22 Feb 2006 11:02:35
Message: <43fc8b1b$1@news.povray.org>
> it does work. It is possible that previous versions did work with 0
> (certainly no negative values) for the most part, but I certainly would
> not want to claim the results were predictable for all animation
> features (i.e. field rendering, subframe rendering, etc).
>     Thorsten
Personally, I've always used an initial frame of 0, and never had any
problems.  So this was really a surprise to me!
...Chambers
Date: 22 Feb 2006 18:05:43
Message: <43fcee47@news.povray.org>
Hmm, the documentation always strongly recommended using one and never
changing it. I am actually surprised the old code didn't have any problems
with it. If there is extremely widespread use of a zero-base, we might have
to see if we can detect it and do something sensible, though I am not sure
that will be possible. Most other features use the 0 to 1 range for
percentages...
	Thorsten
