POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.7.beta.9 available. Server Time
27 Jul 2026 13:51:55 EDT (-0400)
  POV-Ray v3.7.beta.9 available. (Message 21 to 26 of 26)
Subject: Re: POV-Ray v3.7.beta.9 available.
Date: 16 Sep 2005 08:24:03
Message: <432ab963$1@news.povray.org>
Slime wrote:
> I'm sure a lot of people do this, but I wouldn't be surprised to hear of
> someone who had used assumed_gamma properly. For instance, if I had
> discovered assumed_gamma one day and decided I should use it, I would have
> set assumed_gamma 1.8 (for instance) in all my old scenes (since I had
> developed them assuming the viewer had the same gamma my screen did), and
> then used assumed_gamma 1 in all my new scenes. If I also set
> display_gamma=1.8 in povray.ini, my old scenes wouldn't change, and my new
> scenes would be rendered properly for anyone else who had their
> display_gamma set.
This logic won't fly, I am afraid.  In this case all you do is fix the
incorrect use of assumed-gamma in the old scenes (because you had an
incorrectly set display-gamma).  And it would be easier to do in an INI file
then because you would only have to supply one "old scenes" INI file.
As pointed out, there really should be only one gamma setting, not two.
	Thorsten
Date: 17 Sep 2005 23:31:45
Message: <ol3vv2-v69.ln1@raf256.com>
Thorsten Froehlich <43296e79$1@news.povray.org> Thursday 15 of September
2005 14:52
> This really has been answered more than once now in this group!!!  But as
> usual, Raf256 cannot be expected to read old messages and has to ask again
No, I didnt noticed the follow-up-to until now...
Date: 18 Sep 2005 10:20:00
Message: <web.432d76b03eaa28d56cc14b5c0@news.povray.org>
Chris Cason <nos### [at] deletethispovrayorg> wrote:
>   o Radiosity support is still very alpha and there are numerous issues.
Hi all! I've started fooling around with radiosity and... not that i want to
sound rude to our beloved developing team, but i can't seem to get anything
sensible when radiosity is on, even in the simplest situations.
For instance, a red box over a plain plane (which can be thought of as a
beta version of the rsocp) leads to the results posted in pbtb. I don't
know the insides of Povray, but i'd say that currently the radiosity
samples are not distributed randomly in all directions of space, but rather
chosen following a wicked kind of reflection.
The sphere case is yet weirder, a cap of the sphere looks like it's been
bumped in.
I tried to play with:
- count: Seems to do nothing at all.
- error_bound: does have an effect, the lower, the sharper the image.
- recursion_limit: does **strongly** slow down the rendering, much more than
in 3.6.1a.
- pretrace_end: the lower, the smoother the results, as expected.
Well, i'm willing to keep testing and identifying... but maybe i'd need
pointers from experienced beta testers. Thanks!
JYR
Date: 18 Sep 2005 11:24:42
Message: <432d86ba$1@news.povray.org>
<snip>
As we said, it is in an alpha state, and does not really work in many, many
cases.  We had to release a new beta but radiosity just needed a tiny bit
more work than we had time for to get those things worked out.  A new beta
will appear in a few days or so and add the corrctions we were working on.
This is a beta test and we marked radiosity as in an alpha state, so what
you report is expected and the simplest thing is to not waste your time on
it when you notice it doesn't work for you until we say we think we have
worked out the major known problems.
	Thorsten
Date: 18 Sep 2005 18:25:01
Message: <web.432de8263eaa28d56cc14b5c0@news.povray.org>
Point well taken Thorsten, thanks for your detailed and explanatory answer.
As a non-developper myself, i didn't exactly know what to expect from a
"very alpha" feature.
> the simplest thing is to not waste your time on it
.... and i'll quit wasting yours, by the way!!! :)
JYR
Date: 19 Sep 2005 04:46:17
Message: <432e7ad9@news.povray.org>
I've just run the source you posted through the current code, which has had a
number of fixes put into it since beta.9 was released, and it now renders
identically to version 3.6 ... the radiosity really needed fixing before we
released beta 9 but I didn't want to let the old one expire without a new
beta being released.
I'll post a beta 9a shortly with the fixed radiosity.
-- Chris
