POV-Ray : Newsgroups : povray.beta-test : Animation capabilty complete yet? beta 7 Server Time
27 Mar 2026 14:23:42 EDT (-0400)
  Animation capabilty complete yet? beta 7 (Message 1 to 10 of 11)
Subject: Animation capabilty complete yet? beta 7
Date: 25 Jul 2005 23:05:33
Message: <42e5a87d$1@news.povray.org>
I've seen a difference in one example scene animation from 3.6.1 and
3.7.beta.7.
Since I was checking on this new beta for its "animation support" I went
about editing the file Scenes\Animations\speclr.pov so it would show
roughness variations along with the already changing specular amount, which
it already did, then realized the decimal number returned by str() was
skipping 0.1 (going directly from 0.0 to 0.2).
Next I found Cyclic_Animation in the file speclr.ini didn't seem to work the
same as in 3.6, or at least that something was different about it. That
meaning, the final scene values don't stay the same between the two
versions. In this particular case my roughness value went negative due to
there being one too many calculations with the clock variable.
Sorry, I haven't delved far into this, I just thought it peculiar that there
would be any differences like this between the program versions at all and
maybe this could be a bug. Or I thought perhaps the animation functionality
might still be incomplete. Hopefully I'm not trying to report something
prematurely.
P.S. another hurray for Chris and all others involved in getting this beta
out.
Subject: Re: Animation capabilty complete yet? beta 7
Date: 25 Jul 2005 23:08:35
Message: <42e5a933$1@news.povray.org>
Sorry about the incorrect date of my posting this. Had tried the previous
beta again and neglected to switch my system clock back to today.
Date: 26 Jul 2005 09:27:01
Message: <42e63a25$1@news.povray.org>
I was looking at this again this morning, using the unmodified
scenes\animations\speclr.pov and speclr.ini files, and the two POV-Ray
versions (3.6.1 and 3.7.beta.7 {icl8}) definitely use 'clock' differently.
Again, checking this in version 3.6 shows the clock (or specular value)
counts like:
0.0, 0.1, 0.2, 0.3, 0.4, 0.6, 0.7, 0.8, 0.9. Skipping 0.5.
And in the beta this is done like:
0.0, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0. Skipping 0.1.
Also, in the beta, I saw the specular (clock) value go up to 1.1 instead of
remaining at or below 1.0 like it is supposed to. Cyclic_Animation=on keeps
it from going beyond 1.0 but with it "off" it becomes 1.1 at frame 10. So
this seems the important aspect, that clock should never jump over 1.0 even
if cyclic is off... unless the Initial_Clock and Final_Clock aren't
defaults, of course.
Might be something to do with str() but I must leave that up to you to
figure out.
Bob Hughes
Date: 26 Jul 2005 10:29:02
Message: <42e648ae$1@news.povray.org>
> figure out.
What you see is simple rounding differences.  You need to use two digits.
	Thorsten
Date: 26 Jul 2005 13:23:13
Message: <42e67181$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:42e648ae$1@news.povray.org...
Um, I don't think that explains it. I gave it a try just now and saw the
clock (or specular value text) say 1.11 for the last frame when
Cyclic_Animation=off. And it also still jumps directly from 0.00 to 0.22,
skipping 0.11.
So it wouldn't just be rounding errors, right? Seems more like a problem
with clock (and the animation calculation), not something to do with str()
reading.
Date: 26 Jul 2005 17:32:11
Message: <42e6abdb@news.povray.org>
> skipping 0.11.
> reading.
No, that would be a really strange error.  What is your SubsetStartFrame
(spelling?) INI option set to?
	Thorsten
Date: 26 Jul 2005 18:56:47
Message: <42e6bfaf$1@news.povray.org>
news:42e6abdb@news.povray.org...
> Bob Hughes wrote:
>> Seems more like a problem with clock (and the animation calculation), not
>> something to do with str() reading.
Isn't used. The file speclr.ini (in scenes\animations\speclr-- I think I
gave incorrect path to it before) contains only the following:
Antialias=Off
Antialias_Threshold=0.2
Antialias_Depth=3
Test_Abort_Count=100
Input_File_Name=speclr.pov
Initial_Frame=1
Final_Frame=10
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=on
Pause_when_Done=off
When Cyclic_Animation=off the str(S,1,1) in the rendering reads
"specular=1.1" upon reaching the last frame. And #declare S=clock; is where
it gets the value from.
Date: 28 Jul 2005 03:54:29
Message: <42e88f35@news.povray.org>
FYI, I think I have found and fixed the problem: The framenumber used to
compute everything but the initial clock value (which does not need to be
computed) was off by one.  Hence the second frame will appear to have been
dropped and one at the end added.  I think you can work around this by
specifying a substartframe number of 2and asubendframe number of 2 and
render an animation in two parts for now. That should give you the one
missing frame.  The image file numbering will be wrong though, I suspect.  I
suggest renaming the initial frame to "0", backing up the original "2"
frame, renaming the newly rendered frame "2" to "1" and the backup frame to
"2" again.  Then delete the last frame and tellyour movie-creation
application that the first frame has number "0".
	Thorsten
Date: 28 Jul 2005 13:49:10
Message: <42e91a96$1@news.povray.org>
Okay, thanks!
Using your suggestion it's interesting to see that adding:
Subset_Start_Frame=1
Subset_End_Frame=10
Can prevent the skipped value.
Having thought over this particular example scene file a while now I'm
thinking it shouldn't use Cyclic_Animation=on anyhow. Reason being, if it
should run the clock from 0 to 1 to show the specular change by that same
amount cyclic=on would lose part of it. Only way to be sure such animations
use a full clock value would be by using Cyclic_Animation=off.
As it currently is, the following INI setup allows the expected rendering of
the example scene file:
Initial_Frame=1
Final_Frame=10
Initial_Clock=0
Final_Clock=1
Subset_End_Frame=10
Cyclic_Animation=on
Problem is, doesn't seem correct to use cycling and still see the whole
clock run from 0 to 1. Should be dropping part off.
I went back to POV 3.5 and it was the same behavior as in 3.6 using the
above setup, they both run the clock from 0 to 0.9; but with cyclic off they
both skip 0.5 (due to the rounding). However, version 3.7 beta 7 runs it
from 0 to 1 (in tenths) okay when cycling, but continues to 1.1 when not
cycling.
I just wanted to reiterate that point because I think such a scene file
shouldn't use cycled animation.
Not only is that different, from the previous versions, I just now noticed
the frame numbers shown in the status are going from 1 through 11 instead of
1 through 10.
Good luck with any fixes you guys can do with the program, sounds like you
already know what the problem is about. All the animation example scenes
will need some checking but maybe that should be held off until the next
beta...? Or does anyone think that this is a necessary thing (making
possible changes to the examples)?
Bob Hughes
Date: 28 Jul 2005 14:17:50
Message: <42e9214e$1@news.povray.org>
Bob Hughes wrote:
> Okay, thanks!
> Subset_End_Frame=10
Yes, because then the initial clock value has to be computed while otherwise
it is just set to zero.
	Thorsten
