POV-Ray : Newsgroups : povray.beta-test : Memory Leak in SSE2 b3 Server Time
26 Apr 2026 17:04:40 EDT (-0400)
  Memory Leak in SSE2 b3 (Message 1 to 10 of 10)
Subject: Memory Leak in SSE2 b3
Date: 4 May 2005 10:18:22
Message: <4278d9ae$1@news.povray.org>
I have a large scene file that causes a memory leak in the SSE2 version of
beta3.  The first rendering uses up to 300MB of memory which stays allocated
even when the render is done and I close the output window.  After the
second rendering, pvengin-sse32.exe has 470MB allocated.  I am rendering
using the standard ini file with "+fn +w800 +h600" as my options.
There is also a second issue that POV-Ray does not seem to give up when it
cannot allocate more memory.  When I ran my system out of memory running
POV-Ray, it just unallocates a chunk of 30MB or so then reallocates it in an
infinite loop.  When I clicked stop, POV-Ray took its time with the swap
file, but eventually stopped.  When I then clicked the close button (X in
top right), I got the error message posted in beta-test.binaries with this
subject.
I am working on isolating the problematic code.  It is a rather simple scene
with:
1) just a couple area lights unioned with media in a difference of cylinders
2) a LOT of cylinders unioned together with individual pigments made using
rand
3) some boxes.
If there is a known issue with any of these features, I will stop hunting
for the problem, otherwise, I will trim the scene to the minimum cause.
-Nathan
WinXP Pro SP2
1GB (2x512MB) RAM
Pentium 4M 2.2GHz
PovRay 3.7.0.beta3.icl8-sse2.win32
Subject: Re: Memory Leak in SSE2 b3
Date: 4 May 2005 10:29:51
Message: <4278dc5f$1@news.povray.org>
How did you determine this?
	Thorsten
Date: 4 May 2005 10:53:18
Message: <4278e1de$1@news.povray.org>
That is according to Task Manager.  (I know, not a reliable source.)  On
that same note however, the VM Size increases by 70MB per additional run.
I know that there is a leak because after 3-4 renders, my computer starts
using its swap file like crazy and nothing runs or refreshes very quickly,
whereas it does during the first few renders.
I have trimmed my code down to a (very) small sample scene that exhibits the
problem.  After each rendering pass POV-Ray consumes 10MB more VM space
according to Task Manager.  This is compared to 3.6.1a which even after 10
renders only uses a combined total of Mem and VM 10512K + 6224K = 16736K
(much less that 3.7 would be (10MB*10=100MB each for both Mem and VM)).
Sample Scene: ( just 2 comments)
//Begin Sample
//End Sample
-Nathan
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:4278dc5f$1@news.povray.org...
>> The first rendering uses up to 300MB of memory which stays allocated even
> Thorsten
Date: 4 May 2005 10:54:32
Message: <4278e228$1@news.povray.org>
After investigating further, I think the Closing bug may happen when you
click the close button (X) while pov is in the stopping state.  Another odd
fact is that POV continues to acquire more memory even though it is
"stopping".
-Nathan
"Nathan Shomber" <nat### [at] rejgondcom> wrote in message
news:4278d9ae$1@news.povray.org...
>allocated even when the render is done and I close the output window.
>After the second rendering, pvengin-sse32.exe has 470MB allocated.  I am
>rendering using the standard ini file with "+fn +w800 +h600" as my options.
> an infinite loop.  When I clicked stop, POV-Ray took its time with the
> swap file, but eventually stopped.  When I then clicked the close button
> (X in top right), I got the error message posted in beta-test.binaries
> with this subject.
> scene with:
> cylinders
> rand
> 3) some boxes.
> -Nathan
> WinXP Pro SP2
> 1GB (2x512MB) RAM
> Pentium 4M 2.2GHz
Date: 4 May 2005 11:38:00
Message: <4278ec58$1@news.povray.org>
The memory increase appears to be related directly proportionally to the
image size (at least for the blank scene).
ie: +w800 +h600 leads to a 9MB increase
+w8000 +h600 leads to a 90MB increase as does +w800 +h6000.
Perhaps a pixel buffer isn't getting flushed after the file is
saved/displayed/closed?
A slightly Different Issue:
The amount of memory that is allocated and unreturned each render increases
with the number of objects in the scene.  My sample was rendered with "+w1
+h1 +fn"
camera{
    location <1,0,0>
    look_at <0,0,0>
//i=100000: 3.7 uses 60MB per render 3.6.1a used up to 87MB but dropped to a
100kB increase.
//i=10000: 3.7 uses 4MB per render 3.6.1a no net increase at all
//i=1000000: 3.7 uses 722MB per render 3.6.1a used 810MB but dropped to
7.7MB once the render finished.
#local i=100000;
#while (i>0)
    #local i=i-1;
    sphere{
        <i,i,i>,.5
Are the objects not being erased from memory in 3.7?
-Nathan
news:4278e1de$1@news.povray.org...
> the problem.  After each rendering pass POV-Ray consumes 10MB more VM
> space according to Task Manager.  This is compared to 3.6.1a which even
> after 10 renders only uses a combined total of Mem and VM 10512K + 6224K =
> 16736K (much less that 3.7 would be (10MB*10=100MB each for both Mem and
> VM)).
> //Begin Sample
> //End Sample
> -Nathan
>> Thorsten
Date: 4 May 2005 11:38:47
Message: <4278ec87$1@news.povray.org>
oops, wrong branch of the tree... with my last post
Date: 4 May 2005 11:39:25
Message: <4278ecad$1@news.povray.org>
Wow, I just can't used my newsreader.  It was in the right branch!
news:4278ec87$1@news.povray.org...
Date: 4 May 2005 12:18:19
Message: <4278f5cb@news.povray.org>
> "stopping".
> -Nathan
Hm, The memory increase while it's 'stopping' could be due to the
current sample's tracing progress taking more and more memory. Also,
could occur while computing photons. I don't remember if 3.7 has them
enabled or not. I'm just waiting for a more stable beta release before I
seriously play with it. It's a very early beta from what I can see, and
is still missing some features.
~Mike
Things! Billions of them!
Date: 4 May 2005 12:30:04
Message: <4278f88c$1@news.povray.org>
I'm not using photons, so I agree with your first guess.
-Nathan
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:4278f5cb@news.povray.org...
> Hm, The memory increase while it's 'stopping' could be due to the current
> sample's tracing progress taking more and more memory. Also, could occur
> while computing photons. I don't remember if 3.7 has them enabled or not.
> I'm just waiting for a more stable beta release before I seriously play
> with it. It's a very early beta from what I can see, and is still missing
> some features.
> ~Mike
Date: 4 May 2005 15:56:56
Message: <42792908@news.povray.org>
The main leak you would have been seeing was (as you suspected), the code was
not freeing the image memory when it deleted the image object. This has been
fixed.
There will probably be numerous other leaks since we have transitioned to a
system where all POV objects are represented by C++ classes and allocated
with new instead of our old malloc-based system, which provided us the means
to track memory usage and find leaks.
Once the main rendering issues settle down we'll spend some time tracking
down any memory leaks that have been introduced due to these changes and fix
them (as well as adding the ability to track memory usage of native C++ objects).
-- Chris
