POV-Ray : Newsgroups : povray.beta-test : (beta 2) Random crashes on syntax errors Server Time
25 Jun 2026 15:42:35 EDT (-0400)
  (beta 2) Random crashes on syntax errors (Message 1 to 6 of 6)
Subject: (beta 2) Random crashes on syntax errors
Date: 19 Apr 2005 03:10:48
Message: <4264aef8@news.povray.org>
I'm getting random crashes when there's a syntax error. Just start
povray, create a new file, write some garbage and try to render: It will
most probably crash. If it doesn't, close povray, restart it and render.
(Often if you modify the file, save and render then it will not crash,
but if you close povray, restart it and then render it will.)
  Is anyone else getting this?
Subject: Re: (beta 2) Random crashes on syntax errors
Date: 19 Apr 2005 03:19:59
Message: <4264b11f@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:4264aef8@news.povray.org...
Yes, I just tried it and the same thing happens.  If I write some random text
and try to render, it crashes.
Lance.
thezone - thezone.firewave.com.au
Date: 19 Apr 2005 03:29:40
Message: <4264b364$1@news.povray.org>
I think so. I'm definitely getting "random crashes" during parsing, and I
know that in at least some of those cases I had syntax errors and the
crashes stopped when I fixed them.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Apr 2005 05:42:09
Message: <4264d271@news.povray.org>
Thanks for the report, I have fixed this (or at least one cause of it). I
have put a file up temporarily at http://www.povray.org/beta/temp.zip so you
can test it (I will delete this in a day or so).
-- Chris
Date: 19 Apr 2005 06:36:13
Message: <4264df1d@news.povray.org>
"Chris Cason" <nos### [at] deletethispovrayorg> wrote in message
news:4264d271@news.povray.org...
This seems to have fixed the problem in the scenes I was trying.  It now
correctly stops at, and highlights, the syntax error instead of crashing.
Lance.
Date: 19 Apr 2005 06:37:15
Message: <4264df5b@news.povray.org>
  Couldn't get it to crash anymore, so I suppose that took care of it.
