POV-Ray : Newsgroups : povray.beta-test : Beta 4 crashes upon completing a render Server Time
10 Apr 2026 09:01:24 EDT (-0400)
  Beta 4 crashes upon completing a render (Message 1 to 9 of 9)
Subject: Beta 4 crashes upon completing a render
Date: 17 Apr 2004 11:52:45
Message: <4081527A.7010209@hotmail.com>
I can run a render and stop it midway without a problem, but once a
render is complete I get the message, "This program has performed an
illegal operation and will be shut down. If the problem persists,
contact the program vendor." Here are the details of the message:
PVENGINE caused a general protection fault
in module KRNL386.EXE at 0002:00005c48.
Registers:
EAX=5307000a CS=014f EIP=00005c48 EFLGS=00000297
EBX=00950596 SS=4a4f ESP=0000bce2 EBP=0000bcf4
ECX=0000fff6 DS=5307 ESI=00000000 FS=47ef
EDX=00010008 ES=0177 EDI=000005a0 GS=0000
Bytes at CS:EIP:
f2 ae e9 a9 ff 33 c0 33 d2 e9 05 00 47 8b c7 8c
Stack dump:
057e015f 059f0000 53070008 00080000 bd140008 000061ac 057e5307 be340177
0000004f 01770000 0000057e 004fbe34 beba0177 be34537e 00004a4f 00005307
This is my first time beta-testing POV 3.6.
I'm running a machine with these attributes:
*Pentium 4, 1.6 ghz
*Windows 98
*256 mb ram
*40 gb hd
-Samuel Benge
Subject: Re: Beta 4 crashes upon completing a render
Date: 17 Apr 2004 12:24:07
Message: <40815a27@news.povray.org>
I get the same message, but not on all renders.
A scene that fails will always fail, but not all scenes fail.
Will post an update if I see a pattern.
3.6.beta.4.msvc7.win32
Win98se AMD Duron 1 ghz 512mb
Date: 17 Apr 2004 12:38:47
Message: <40815D43.10805@hotmail.com>
I made a completely blank file and rendered it. I got the usual black
image, but it still crashed afterward. I'll keep tweaking settings to
see what it could be....
-Samuel Benge
Date: 17 Apr 2004 12:52:59
Message: <40816097.2030100@hotmail.com>
Okay, more news about this 3.6 beta 4 weirdness....
POV-Ray 3.5 now crashes just like 3.6 beta 4. The quickres settings have
reverted to their defaults, giving me none of custom settings I created
for it.
ML-POV still renders perfectly, as far as I can see. POV-Ray 3.5 is
unusable now.
-Samuel Benge
Subject: Re> Beta 4> Another important message
Date: 17 Apr 2004 13:04:21
Message: <40816341.4060007@hotmail.com>
Sorry to cluster-post like this, but.....
It may be important to note that when I uninstalled 3.6 beta 4 and
rebooted my computer, the POV 3.5 icon was missing from my desktop. I
found the icon in the usual place and put it back onto my desktop. Ran
POV-Ray 3.5 and it worked fine.
I think somehow 3.6 beta 4 'took over' that desktop icon and made me
think I was using 3.5... when it's very possible I was using 3.6 beta 4!
This could explain why version 3.5 stopped working normally.
-Samuel Benge
Date: 17 Apr 2004 13:06:58
Message: <40816432@news.povray.org>
In article <408### [at] hotmailcom> , Samuel Benge
> for it.
Well, are you sure you system isn't just corrupted?  There is no connection
between 3.5 and 3.6 beta, so what you observe is completely unrelated and
thus caused by something else.
    Thorsten
e-mail: tho### [at] trfde
Date: 17 Apr 2004 14:00:23
Message: <408170b7$1@news.povray.org>
Program ended abnormally on 17/04/2004 12:23, Due to a catastrophic StephenS error:
Same here.  Even the trick i used to get beta 2 to not crash ( disabling all
messages with -ga) no longer works.  :(
AMD Athlon 650 MHz.
512 MB ram
Win98 SE.
Subject: Re: Re> Beta 4> Another important message
Date: 18 Apr 2004 08:32:42
Message: <4082756a@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:408### [at] hotmailcom...
I will look into this. It could be some weirdness in the installer.
While the two versions do use seperate registry settings it is possible
that a bad setup file could do things to the old settings.
-- Chris
Date: 25 Apr 2004 04:17:14
Message: <mesnews.ca697d44.2987014a.176.837@spampovmonde.org>
I have the same crash.
The message are juste :
"Pvengine cause a error in the KRNL.386
The program Pvengine stop now...."
Pvengine had the same crash with the beta 2.
Version 3.6.beta.4.msvc7.win32
OS Windows ME
AMD Athlon XP, 1666 MHz (6.25 x 267) 2000+
carte Asus A7V8X
Chipset VIA VT8377 Apollo KT400
512 Mo  (DDR SDRAM)
Carte video   ASUS V9520 Magic V45.23
Martial
http://cathemline.org
