POV-Ray : Newsgroups : povray.beta-test : +C +F options on a new file causes parsing to stop Server Time
16 May 2026 14:02:34 EDT (-0400)
  +C +F options on a new file causes parsing to stop (Message 1 to 7 of 7)
Subject: +C +F options on a new file causes parsing to stop
Date: 1 Feb 2004 06:20:18
Message: <401ce0f2$1@news.povray.org>
Using the +C +F options (resuming and file output) when the file doesn't
exist yet causes the parsing to abort with an error message saying "Continue
Trace Error: Error opening BMP image". +C alone (without file output)
doesn't cause the problem.
This is new behaviour: in previous versions, POV-Ray gave the message
"Warning: Cannot open continue trace output file. Opening new output file"
and went on rendering, which is more practical IMHO.
3.6b1, Windows XP HE SP1, 1 Gb RAM
http://www.oyonale.com
- Graphic experiments
- Posters
Subject: Re: +C +F options on a new file causes parsing to stop
Date: 1 Feb 2004 06:44:03
Message: <4o4ve1-di8.ln1@triton.imagico.de>
Does this only happen with sys (bmp) file format or also with others?
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 1 Feb 2004 08:23:38
Message: <401cfdda$1@news.povray.org>
news:4o4### [at] tritonimagicode...
"Continue
Only with the sys format (+F or +FS on Windows).
G.
- Posters
Date: 11 Mar 2004 09:59:34
Message: <40507ed6@news.povray.org>
"Gilles Tran" <gitran_nospam_@wanadoo.fr> wrote in message
news:401cfdda$1@news.povray.org...
> "Continue
I'm just fixing this now.
What would you prefer it do in the case where the file exists, but is (a) corrupt, (b)
of the wrong format (e.g. bit-depth), or (c)
of the wrong resolution.
-- Chris
Date: 11 Mar 2004 22:13:51
Message: <40512aef$1@news.povray.org>
Program ended abnormally on 11/03/2004 09:59, Due to a catastrophic Chris Cason
error:
>>"Continue
(b) of the wrong format (e.g. bit-depth), or (c)
You could warn the user and offer and interactive choice to:
(a) start from scratch, overwriting the file.
(b) start from scratch, renaming the previous file.
(c) continue using the original file's resolution and color depth.
(d) abort the render.
Or maybe, if and interactive choice is not a good idea, have these behaviours be
part of an .ini setting.
Date: 12 Mar 2004 01:52:16
Message: <40515e20$1@news.povray.org>
"Francois Labreque" <fla### [at] videotronca> wrote in message
news:40512aef$1@news.povray.org...
(a) corrupt, (b) of the wrong format (e.g. bit-depth), or (c)
behaviours be
Ahem. Please excuse me if I am making this seem trivial. Maybe there should
only be a warning telling of the incompatible file so the user can check
into that themselves.
This error was about a default system output file not being continuable, so
with that fixed (whether about the file itself or only the switch +F) I'd
think it simpler to just warn with a text message that there is a fault with
the file intended for usage. Most any typical circumstance would be that a
partial (and correct) image file is awaiting continuance and be written to.
Specifying a different output type would obviously be a mistake.
Now, I'll take back what I say here if Francois' suggestion were to be
invoked for every file type, because that means a person might be trying to
juggle image files around and would need the extra presentation of options
before allowing the +C switch to have control automatically. Guess that was
the idea about additional INI settings, to intervene in various ways. If you
can see it my way a moment, what I'm trying to convey here is that a popup
dialog asking to make a few choices either needs plenty of info passed to
the user (more than just "there's a problem"), or can cause the user to need
to go check on the file anyhow while that dialog sits awaiting a response.
Hopefully I'm making some sense. For me, a continued trace is always just
that, continued and not changed. On the other hand, I'd hate to see a
potentially usable file overwritten from the start by mistake too. But this
depends on how much failsafe you think ought to be built in to guard against
that happening, regardless of how one might get named and placed the same as
what would be done during the next render.
Bob H.
Date: 13 Mar 2004 13:21:58
Message: <40535146@news.povray.org>
news:40507ed6@news.povray.org...
It should stop and show an error message explaining the problem as precisely
as possible. I don't see much the point of continuing a render in these 3
cases.
G.
- Posters
