POV-Ray : Newsgroups : povray.beta-test : [Docs] A couple of errors in the .pdf Server Time
29 Jul 2024 08:23:10 EDT (-0400)
  [Docs] A couple of errors in the .pdf (Message 1 to 2 of 2)
Subject: [Docs] A couple of errors in the .pdf
Date: 31 Jan 2004 00:07:41
Message: <401b381d$1@news.povray.org>
I assume that these have already been flagged for a later update, but just in case:
Table of contents:
Figures:
	5.1	The Mie  (I think it should be "Mie Haze")
	5.2	The Mie  (I think it should be "Mie Murky")
	The figures in chapter 5 have the same problem.
Tables:
	The tables for chapter 2 do not have titles.
1.1.3 Float expressions
LOGICAL_OPERATOR:
& | | <em>(note: this means an ampersand or a vertical bar is a logical
operator)</em>
INT:
FLOAT <em>(note any syntax which requires a integer INT will accept a FLOAT and
it will be truncated to
	The "<em>" and "</em>" tags shouldn't be there, IMHO.  Also, the second note is
truncated after the word "truncated". ;-)
Tables 1.2, 1.3 and 1.4 do not appear in the section that talk about them.
sin(A) has an illegible description.
1.1.5 Specifying colors
COLOR:
	<em> tags again!
1.1.6 User defined functions
IDENT_ITEM:
	More <em> tags.
1.2.5 The #version Directive
	There are multiple references to 3.5 being the current version.
Subject: Re: [Docs] A couple of errors in the .pdf
Date: 1 Feb 2004 03:30:18
Message: <Xns948260B0BFD65seed7@news.povray.org>
> just in case:
I'll have a look,
Ingo
