POV-Ray : Newsgroups : povray.beta-test : Known bugs 27 Nov 2001 Server Time
13 Oct 2025 06:54:19 EDT (-0400)
  Known bugs 27 Nov 2001 (Message 1 to 1 of 1)
Subject: Known bugs 27 Nov 2001
Date: 27 Nov 2001 02:33:03
Message: <4$4pADApE0A8EwN5@econym.demon.co.uk>
KNOWN BUGS
Blob problem (job000189)
and Blob : Toward a solution
(blob surface develops holes when "radius" is very small)
http://news.povray.org/3b99052c@news.povray.org
http://news.povray.org/3B991C90.D715B7A3@free.fr
Superellipsoid epsilon to big ? (job000190)
(strange dark patches occur on a superellipsoid when the east-west-
exponent is set very small)
http://news.povray.org/3b992a81@news.povray.org
Additional (?) blob bug
(blob component disappears when radius is 317 or greater)
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
(also reported as: Blob rendering error (job000136))
http://news.povray.org/Xns91203DC7F3CCQ@204.213.191.226
hf_gray_16 + png creates wrong output image (job000173)
(global_settings {hf_gray_16} causes "Cannot open output file")
http://news.povray.org/3BA3BAE6.4671C0BB@free.fr
Small window title bug ()
(Title switches back to "POV-Ray for Windows" after minimize or
restore.)
http://news.povray.org/3ba92966$1@news.povray.org
Rendering animation (MS Windows) (job000178)
(Message that indicates the frame to be render is displayed AFTER the
rendering.)
http://news.povray.org/3BAC1D0C.74A4A503@free.fr
sin(X)^sin(X) -> crash! (job000179 and job000180)
http://news.povray.org/3baf7992@news.povray.org
Spline bug (job000182)
(The spline path is all wrong when certain time values are used.)
http://news.povray.org/3bb41dc8@news.povray.org
Strange spline problem (job000181)
(Changes from render to render. Control points are sometimes missing.)
http://news.povray.org/Xns9136AC2E64F60seed7@povray.org
Highlight bug (job000137)
(highlights are sometimes visible where they should be in shadow)
http://news.povray.org/3bb4cf08@news.povray.org
Macro bug (job000146)
(POV can dereference a deallocated pointer if you return a local from a
macro.)
http://news.povray.org/3BB4ED11.8EC69CEC@hotmail.com
(also reported as: strings operations crash with both compiles
http://news.povray.org/e3piut8anmf4cli4pnfmstadgc3nleqvb2@4ax.com)
Number of parameters in functions (job000174)
(?is this the same as "function re-declaration crash"?)
http://news.povray.org/kc3hqtkgj93f82rpkj6puvlj8f5cs7nk0q@4ax.com
Bug with intersection stack (with crash)(job000175)
http://news.povray.org/5f13rtc0v0rso4fk7lut5e0980qa9g756b@4ax.com
Radiosity sampling, with fix method (job000177)
(radiosity sample counter is reset to the start every time, sampling
artefacts are produced)
http://news.povray.org/3BC5A13E.9C022BD6@reading.ac.uk
Slow rendering when using +ua and antialiasing method 1 (job000191)
(No details available)
http://news.povray.org/3bbf6347@news.povray.org
Delayed syntax checking (job000192)
(declare without the "#" can cause a much later line to fail to parse
Parser will ignore the first token following old-style declares without
a #.)
http://news.povray.org/AM3LOAABMO27EwFh@econym.demon.co.uk
[bug] orthographic camera bug?
(objects sometimes disappear when the orthographic camera is used)
http://news.povray.org/3bdca5eb@news.povray.org
Bug: dispersion_samples affects photon brightness (job000193)
http://news.povray.org/MPG.1631c5fca936293298969e@news.povray.org
Jpeg and memory problem during animations (job000194)
(It seems that some memory is not properly released between frames when
a jpeg file is used)
http://news.povray.org/3be2ef0d@news.povray.org
Bug with blobs and media
(possibly related to  blob surface develops holes when "radius" is very
small)
http://news.povray.org/3be5f0b2@news.povray.org
Render Window Bug
(Render window pops up when application minimised, after which the
application doesn't open when clicked on the task bar.)
http://news.povray.org/3bde157e@news.povray.org
Another strange photon behavior (job000195)
(a: bright colored caustics. b: holes/circular black spots)
http://news.povray.org/MPG.16510f3e44067d3f9896ae@news.povray.org
panoramic projection bug? (job000196)
(When "angle" keyword within camera statement appears after "panoramic"
keyword then looks like ignored.)
http://news.povray.org/avnfut8fof5ualgf8hnrtpl1knlg8828sp@4ax.com
Alpha problems: text is not antialiased (job000187)
(black objects are not antialiased on Unix and Windows versions, alpha
is not correctly output on Mac)
http://news.povray.org/3bea5a84$1@news.povray.org
Black outline in smooth meshes
(The outline of smooth meshes exhibit black dots or areas (which go away
with double_illuminate))
http://news.povray.org/3bf6794e$1@news.povray.org
User_Abort_Command
(User_Abort_Command does not seem to work at all)
http://news.povray.org/Xns913D9F7268736seed7@povray.org
First report from bugreports
http://news.povray.org/u12outsm2kso3k5ef4lp26ogm5cvsm46ge@4ax.com
Re: trivial question on topic
(Poly Object Bug)
http://news.povray.org/3BEBEB4C.CA854309@pacbell.net
Camera is off by half a pixel
http://news.povray.org/3bccc696@news.povray.org
Light_sources in light_groups don't cast shadows
(rendering without light buffers (-UL) puts the shadows back)
http://news.povray.org/3bfd4d63@news.povray.org
        BUGS REPORTED FIXED IN BETA 7
Crash when stopping in the first line (job000162 and job000168)
http://news.povray.org/1103_1002737295@iq
(Also reported as: Radiosity crash when user stops render during
pretrace.)
http://news.povray.org/3bb4605d$1@news.povray.org
Stop during mosaic: crash
http://news.povray.org/Xns9126925CDC108seed7@povray.org
Photon problems
http://news.povray.org/3bc4d0a9$1@news.povray.org
Isosurface - contained_by
http://news.povray.org/3bc6ffd9@news.povray.org
        BUGS THAT HAVE GONE AWAY IN BETA 7
Sphere_sweep plus radiosity bug (job000176)
(Colored sphere_sweeps lead to bad radiosity.)
http://news.povray.org/3b9670b2@news.povray.org
Bug in texture_map (job000183)
(after shortening a too long blend map, POV-Ray crashes in the next
render)
http://news.povray.org/3ba9f8e9$1@news.povray.org
        BUGS REPORTED FIXED IN NEXT BETA
marble + turbulence bug
(marble turbulence now looks very different)
http://news.povray.org/Xns914AC563F6C36seed7@povray.org
(Intel compilation only: previously reported as "loop bug" for beta 5)
(also causes crackle2.pov and crackle3.pov to crash under the Intel
compile)
http://news.povray.org/3bdfcdf7@news.povray.org
Possibly fixed in next beta
Isosurfaces *much* slower in beta 7?
(isosurfaces with "evaluate" are now very slow)
http://news.povray.org/3bdf24b3$1@news.povray.org
rand.inc VRand_In_Sphere flaw
(VRand_In_Sphere doesn't give uniform distribution)
http://news.povray.org/3bc64790$1@news.povray.org
Are '&' and '|' swiched?
(when used in a function operating on numbers they have the opposite
effect)
http://news.povray.org/Xns9128A184570B3seed7@povray.org
function(a){a<=0} returns the wrong value when a=0
http://news.povray.org/Xns9128A519E6F15seed7@povray.org
When outputting to PNG, the wrong gamma correction value is written
http://news.povray.org/3be12811@news.povray.org
agate pattern broken
(different results with intel and msvc compile)
http://news.povray.org/3BE46299.421893B7@gmx.de
Bug with declaration with no dimensions
http://news.povray.org/scpitt851apfq5r6qtsoi1vpupt77g829s@4ax.com
Status line bug
(status line keeps saying "Parsing..." instead of telling me what the
error was)
http://news.povray.org/3bde062f@news.povray.org
WinPov crash with too many max_gradient warnings
(previously reported as: "[Bug] Output of too many evaluations cause
strange behavior", but it didn't actually crash beta 4 or  beta 5)
http://news.povray.org/3BE026F0.B59858FA@gmx.de
Using charset sys crashes povray
http://news.povray.org/3bfb4d8c@news.povray.org
Mike Williams
Gentleman of Leisure
