POV-Ray : Newsgroups : povray.beta-test : [doc] concat with one parameter Server Time
16 May 2026 16:31:32 EDT (-0400)
  [doc] concat with one parameter (Message 1 to 10 of 16)
Subject: [doc] concat with one parameter
Date: 21 May 2002 05:13:24
Message: <3cea0fb4@news.povray.org>
RC5 for Unix
#debug concat("POV")
works fine, but the doc says:
concat(S1,S2,...)
IMO the doc and not the function should be changed because this is a useful
feature to give an RVALUE (and not an IDENTIFIER) as parameter to a macro.
Or is there a better (shorter) way?
Felix Wiemann
Subject: Re: [doc] concat with one parameter
Date: 21 May 2002 06:36:28
Message: <3cea232b@news.povray.org>
  I don't understand why you can't give the value directly.
Date: 21 May 2002 11:07:48
Message: <3cea62c4@news.povray.org>
If the string is modified inside the macro but the original string is
needed after execution, it's necessary to use concat. For example:
#macro M(S)
        #debug "\n"  // linefeed
        #debug S     // "POV-Ray"
        #debug "\n"
        #declare S = substr(S, 5, 3)  // S = "Ray"
        #debug S     // "Ray"
        #debug "\n"
#declare S = "POV-Ray"
M(concat(S))
#debug substr(S, 1, 3)  // "POV" or "Ray"
The output is:
POV-Ray
Ray
POV
but if you change M(concat(S)) to M(S) the output is:
POV-Ray
Ray
Ray
Felix Wiemann
Date: 21 May 2002 11:51:57
Message: <pan.2002.05.21.10.54.53.841372.2143@mac.com>
In that case, either the macro is written wrong or you are using it
wrong. The concat() function is for concatenating strings, not making
temporary copies. I don't see any reason to document that use, it is
basically a hack and should be discouraged because it leads to code that
appears to do something other than what it really does.
If you don't want to declare a temporary variable, a macro is a better
solution than misusing the concat() function. Something like:
#macro clonestring(String)
    #local tmpString = String
    tmpString
POV-Ray TAG e-mail: <chr### [at] tagpovrayorg>
WWW: http://homepage.mac.com/chrishuff/
Date: 22 May 2002 07:53:39
Message: <3ceb86c2@news.povray.org>
Where's the problem with concat? It works fine. Aren't POVers (and computer
users in general) known for using a function for something totally
different than it was designed for? And I don't see any possibility that's
as short as concat.
Why?
>     tmpString
> #end
Is much longer. So not better but worse.
Felix Wiemann
Date: 22 May 2002 09:22:18
Message: <3ceb9b89@news.povray.org>
  Have you tried just enclosing the string in parentheses?
>>     tmpString
>> #end
  Perhaps you should learn some basics of (modular) programming.
  "It's much longer" is a really poor excuse for making bad code.
  You have to write one #local more - so what? The alternative is to write
an extra 'concat()' several times, which makes the code quite obfuscated
and longer.
Date: 22 May 2002 09:46:44
Message: <3ceba144@news.povray.org>
What do you mean? Enclose the variable name in parentheses? That of course
won't work. Note that the string itself is normally not available before
parsing so it's necessary to use a variable.
Hmmm... The SDL is actually not very modularized. It's more a description
language than a programming language. Macros and functions are possible but
structures or even classes aren't supported. When I want to write a program
for POV-Ray, I write a C++ program which generates SDL code.
> and longer.
OK, normally it's better to write well understandable code, but I'm
currently working on my signature, so in this case it's very important to
save even a few bytes.
And IMHO it's not a problem to understand what concat with one parameter
does.
Felix Wiemann
Date: 22 May 2002 09:53:48
Message: <3ceba2ec@news.povray.org>
  I said "string", not "variable name".
  When you call your macro, do: MyMacro(("The string"))
  That doesn't mean you shouldn't make your code as modular as the language
allows.
Date: 22 May 2002 14:05:54
Message: <pan.2002.05.22.13.08.54.207328.2163@mac.com>
> computer users in general) known for using a function for something
> totally different than it was designed for? And I don't see any
> possibility that's as short as concat.
It's common so it must be good?
I already explained the problem with using concat(). It is intended for
concatenating strings, not cloning them. To anyone reading the code, it
looks like you made a mistake: the code does not do what it says it does.
That is a bad thing.
> Why?
If you really can't tell...I give up.
>>     tmpString
>> #end
I hope I never have to maintain anything you write...
It is longer by 5 characters, because its name says what it does. That is
a good thing. If the extra 5 characters is that bad, rename it: call it
clnstr() or something. And if you are using it multiple times, it would be
better to skip the macro completely and just use a temporary variable...in
that case, it is shorter than your misuse of the concat() function: the
usual naming convention just adds "tmp" or something similar, which is 5
characters shorter than a call to concat().
Date: 22 May 2002 14:08:26
Message: <3cebde99@news.povray.org>
Sorry, I thought of quotation marks.
In this example it doesn't make sense. MyMacro((S)) doesn't work either,
error: "Expected 'numeric expression', string identifier found instead"
>   language
> allows.
You're right. As I said, I need it for a signature, so it's important that
it's very short.
INGO, could you perhaps update the doc?
| concat(S1,S2,...)
to
| concat(S1,...)
or something similar.
Felix Wiemann
