POV-Ray : Newsgroups : povray.beta-test : [linux] ~/.povrayrc Server Time
17 Feb 2026 17:10:11 EST (-0500)
  [linux] ~/.povrayrc (Message 1 to 8 of 8)
Subject: [linux] ~/.povrayrc
Date: 20 May 2002 14:10:25
Message: <3ce93c11@news.povray.org>
RC5, SuSE Linux 7.3, 128MB, P3 600
An empty .povrayrc in home directory causes POV-Ray to render a 100x100
image without displaying it on screen.
Felix Wiemann
Subject: Re: [linux] ~/.povrayrc
Date: 20 May 2002 14:45:40
Message: <3ce94454$1@news.povray.org>
In article <3ce93c11@news.povray.org> , Felix Wiemann <Fel### [at] gmxnet>
So what?  If you specify not appropriate settings what is supposed to happen?
POV-Ray to guess which image size and display you want when you don't tell it?
    Thorsten
Date: 20 May 2002 14:57:41
Message: <3ce94724@news.povray.org>
> happen? POV-Ray to guess which image size and display you want when you
> don't tell it?
Use the values in povray.ini?
Felix Wiemann
Date: 20 May 2002 15:27:12
Message: <slrnaeij3u.b6k.steve@zeropps.org.uk>
>> don't tell it?
Linux uses .rc files not .ini files, this is a hangover from your windows
day.
Let go of the past and it will all get better:-)
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 20 May 2002 17:26:43
Message: <3ce96a13@news.povray.org>
> day.
From the docs, section 5.1.2  Using INI Files:
Note: although the term 'INI file' is used by POV-Ray, this was implemented
before the widespread acceptance of Microsoft Windows, and while POV-Ray's
INI files are almost identical to those of Windows, there are some minor
differences (the foremost being that it is legal to have multiple instances
of the same item in a section). INI files are used on all platform versions
of POV-Ray, not just on the Windows platform
Anders
P.S. Ingo, that note is missing a period at the end. :-)
Date: 20 May 2002 17:36:09
Message: <3ce96c49@news.povray.org>
In article <3ce96a13@news.povray.org> , "Anders K." <and### [at] prostard2gcom>
>> day.
It says nothing about povray.ini being read at startup, does it?  Actually, it
can't because that is a platform specific thing, so:
The Unix documentation however, does still call the file povray.ini while it
should say povray.rc...
    Thorsten
Date: 21 May 2002 04:16:45
Message: <3cea026c@news.povray.org>
>> implemented before the widespread acceptance of Microsoft Windows, and
>> while POV-Ray's INI files are almost identical to those of Windows, there
>> are some minor differences (the foremost being that it is legal to have
>> multiple instances of the same item in a section). INI files are used on
>> all platform versions of POV-Ray, not just on the Windows platform
It doesn't, but:
There's a povray.ini in povray35 (and if there isn't, POV-Ray generates a
warning).
The windows version uses povray.ini, so the unix version should do so, too.
> Actually, it can't because that is a platform specific thing, so:
Why? There's no problem having a povray.ini on any system (AFAIK at least).
> it should say povray.rc...
When do people learn that Unix doesn't need those stupid windows
extensions? ;) The file is called ".povrayrc".
README.unix says:
   The default povray.ini file that is shipped with the Unix archive
   assumes that POV-Ray will be installed under /usr/local/lib/povray31.
   If you are not installing POV-Ray there, you should edit the
   Library_Path specifications in this file to point to the location
   where POV-Ray is installed.  Each user should copy this file to
   ".povrayrc" in their home directory.
So it's not a bug that POV-Ray doesn't read povray.ini if there's .povrayrc
in home directory, but it's IMO not the expected behavior. I think it might
really be a better solution to read .povrayrc *and* povray.ini because
otherwise the user probably would have to copy povray.ini. The
configuration in povray.ini makes much more sense than (some of) POV-Ray's
default values.
BTW, README.unix (and maybe README, too) have to be UPDATED!
Felix Wiemann
Date: 25 May 2002 12:44:15
Message: <pan.2002.05.25.15.46.31.571292.1802@povray.org>
> .povrayrc in home directory, but it's IMO not the expected behavior. I
> think it might really be a better solution to read .povrayrc *and*
> povray.ini because otherwise the user probably would have to copy
> povray.ini. The configuration in povray.ini makes much more sense than
> (some of) POV-Ray's default values.
The general rule is that more specific files trump less specific files.
There's a system-wide default povray.ini, which can be overridden by a
user-level ~/.povrayrc.  All of this is very typical Unix behavior, though
system-level files are likely to be found in /etc rather than
/usr/local/lib/povray* and end in .conf rather than .ini.  Beyond that, a
more specific collection of default settings can be defined per directory,
which defines things at a project level, which is more specific than
either the user or system level.
Merging collections of settings rather than ignoring everything but the
most specific file isn't a bad idea, but it's a bit late for 3.5. Perhaps
the best thing to do is to copy povray.ini to ~/.povrayrc as specified in
the docs, edit as needed, and copy .povrayrc to foo/povray.ini when
starting a new project, explicitly specifying all settings at each level.
True, there are a bunch of 3.1 references still in there.
-Mark Gordon
