POV-Ray : Newsgroups : povray.beta-test : povray find and replace Server Time
12 Oct 2025 00:40:49 EDT (-0400)
  povray find and replace (Message 1 to 3 of 3)
Subject: povray find and replace
Date: 17 May 2002 19:43:09
Message: <3ce5958d$1@news.povray.org>
I used Search->Replace "theclock" with "theClock".  It appears that the
"replace with" text is always forced to lower-case.  So "theclock" is
replaced with "theclock".  :-(  The "match case" checkbox seems to behave
correctly -- if checked it properly ignores instances of "Theclock", for
example.  There's simply no way to use find & replace to use capitalization.
-Scott
Subject: Re: povray find and replace
Date: 17 May 2002 20:52:45
Message: <3ce5a5dd$1@news.povray.org>
"Scott Wasson" <swa### [at] townispcom> wrote in message
news:3ce5958d$1@news.povray.org...
Try unchecking, rechecking, and finally unchecking Preserve Case. Seems mine
was stuck and I was about to confirm what you found, since I was pretty sure
it used to work okay. Capitals go in fine for me now. Using WinXP here.
bob h
Date: 17 May 2002 21:52:34
Message: <3ce5b3e2$1@news.povray.org>
That did it.  Thank you.  But what's the rationale for having preserve case
enabled by default?  I can see its use for editing Shakespearean lines of
prose, or writing Turkish poetry.  But in a case-sensitive computer
language?
"bob h" <omn### [at] charternet> wrote in message
news:3ce5a5dd$1@news.povray.org...
mine
sure
> bob h
