POV-Ray : Newsgroups : povray.beta-test : Camera movement in RTR demo Server Time
17 Feb 2026 19:02:49 EST (-0500)
  Camera movement in RTR demo (Message 1 to 2 of 2)
Subject: Camera movement in RTR demo
Date: 16 May 2002 16:42:56
Message: <3ce419d0$1@news.povray.org>
Are you planning on fixing the camera movement in the about box easter egg?
Right now, as I move my mouse from the bottom to the top of the screen, the
logo tilts backwards from vertical to horizontal and immediately snaps back
to vertical, then repeats this again. Not only is this very strange, it also
limits the vertical rotation to 0-90 degrees. The light movement has a
similar limitation.
Anders
(POV-Ray 3.5 RC4, Windows 98)
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Subject: Re: Camera movement in RTR demo
Date: 17 May 2002 04:03:20
Message: <3ce4b948$1@news.povray.org>
"Anders K." <and### [at] prostard2gcom> schrieb im Newsbeitrag
news:3ce419d0$1@news.povray.org...
egg?
the
back
also
> similar limitation.
It is intended that the vertical movement is limited to 90 degrees (there is
going to be a background plane is the future).  It should not snap back
however.
    Thorsten
