|  |  | Version 3.5.beta.RC4.icl.win32
Windows ME.  Pentium 4.
Odd file names for files created with the following INI options.
Debug_File=true
    produces file named:  render.out
Fatal_File=true
    produces file named:  stats.out
Render_File=true
    produces file named:  warning.out
Statistic_File=true
    produces file named:  alltext.out
Warning_File=true
    produces file named:  Steve A. Bennett
All_File=true
    produces file named:  David K. Buck
Robert Chaffe
http://www.donovansweb.com/~chaffe/
|  |  | Robert Chaffe <rob### [at] earthlink net> wrote:
> Warning_File=true
> All_File=true
  So what's wrong with this?-)
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}//  - Warp - Post a reply to this message
|  |  | In article <3ce3a4b8@news.povray.org>, Warp wrote:
>> Warning_File=true
>> All_File=true
      not 8.3 compliant ?
| > sur le meme disque. par contre pour se l'instalation de logicielle alors
| > la ces la galer totale, je ne suis pas ariver a en instaler un seul.
| moins bien.			-+- remarque acide dans fcol.debats -+-
|  |  | tontonTh <ton### [at] la buvette  org> wrote:
>       not 8.3 compliant ?
  Why should it be?
  AFAIK POV-Ray 3.5 has not been ported to any system with that limitation.
-1<.7438.1795>1,20)M(1<.77595.13699>30,20)M(3<.75923.07145>80,99)// - Warp - Post a reply to this message
>>       not 8.3 compliant ?
>   Why should it be?
>   limitation.
MS-DOS? OK, *has* not been ported, but will probably.
Felix Wiemann Post a reply to this message
|  |  | "Warp" <war### [at] tag povray  org> wrote in message
news:3ce3a4b8@news.povray.org...
> > Warning_File=true
> > All_File=true
There is nothing wrong with file names,
but they should be different according to docs:
5.2.5.3  Directing Text Streams to Files:
Statistic_File=true Echo statistic text to STATS.OUT
Render_File=true Echo render info text to RENDER.OUT
Warning_File=true Echo warning info text to WARNING.OUT
All_File=true Echo all debug, fatal, render, statistic, and warning text to
ALLTEXT.OUT
It looks like there is a wrong index shift in array with file names. Post a reply to this message
There isn't any text file created on my system, just the output picture.
RC4, SuSE Linux 7.3, P3 600, 128MB
Felix Wiemann
|  |  | "Robert Chaffe" <rob### [at] earthlink net> wrote in message
news:3ce31865@news.povray.org...
> Debug_File=true
> Fatal_File=true
> Render_File=true
> Statistic_File=true
> Warning_File=true
> All_File=true
Confirmed,
P3 W2K
Also reported with previous beta:
http://news.povray.org/povray.beta-test/23412/?ttop=24438&toff=150 Post a reply to this message
  Well, then it will be the headache of the one who is doing the port, not
the team, don't you think?
|  |  | On 16 May 2002 12:34:46 -0400, Warp <war### [at] tag povray  org> wrote:
From documentation: "POV-Ray is intended to be very portable. This isn't just
an issue of philosophy or purism, POV-Ray is really used on a large variety of
different platforms".
ABX Post a reply to this message
