Version 3.5.beta.RC4.icl.win32
Windows ME. Pentium 4.
Odd file names for files created with the following INI options.
Debug_File=true
produces file named: render.out
Fatal_File=true
produces file named: stats.out
Render_File=true
produces file named: warning.out
Statistic_File=true
produces file named: alltext.out
Warning_File=true
produces file named: Steve A. Bennett
All_File=true
produces file named: David K. Buck
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Robert Chaffe <rob### [at] earthlink net> wrote:
> Warning_File=true
> All_File=true
So what's wrong with this?-)
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
In article <3ce3a4b8@news.povray.org>, Warp wrote:
>> Warning_File=true
>> All_File=true
not 8.3 compliant ?
| > sur le meme disque. par contre pour se l'instalation de logicielle alors
| > la ces la galer totale, je ne suis pas ariver a en instaler un seul.
| moins bien. -+- remarque acide dans fcol.debats -+-
tontonTh <ton### [at] la buvette org> wrote:
> not 8.3 compliant ?
Why should it be?
AFAIK POV-Ray 3.5 has not been ported to any system with that limitation.
>> not 8.3 compliant ?
> Why should it be?
> limitation.
MS-DOS? OK, *has* not been ported, but will probably.
Felix Wiemann
"Warp" <war### [at] tag povray org> wrote in message
news:3ce3a4b8@news.povray.org...
> > Warning_File=true
> > All_File=true
There is nothing wrong with file names,
but they should be different according to docs:
5.2.5.3 Directing Text Streams to Files:
Statistic_File=true Echo statistic text to STATS.OUT
Render_File=true Echo render info text to RENDER.OUT
Warning_File=true Echo warning info text to WARNING.OUT
All_File=true Echo all debug, fatal, render, statistic, and warning text to
ALLTEXT.OUT
It looks like there is a wrong index shift in array with file names.
There isn't any text file created on my system, just the output picture.
RC4, SuSE Linux 7.3, P3 600, 128MB
Felix Wiemann
"Robert Chaffe" <rob### [at] earthlink net> wrote in message
news:3ce31865@news.povray.org...
> Debug_File=true
> Fatal_File=true
> Render_File=true
> Statistic_File=true
> Warning_File=true
> All_File=true
Confirmed,
P3 W2K
Also reported with previous beta:
http://news.povray.org/povray.beta-test/23412/?ttop=24438&toff=150
Well, then it will be the headache of the one who is doing the port, not
the team, don't you think?
From documentation: "POV-Ray is intended to be very portable. This isn't just
an issue of philosophy or purism, POV-Ray is really used on a large variety of
different platforms".
ABX
