POV-Ray : Newsgroups : povray.beta-test : Text Streams to Odd File Names Server Time
30 Mar 2026 17:50:28 EDT (-0400)
  Text Streams to Odd File Names (Message 1 to 10 of 13)
Subject: Text Streams to Odd File Names
Date: 15 May 2002 22:24:37
Message: <3ce31865@news.povray.org>
Version 3.5.beta.RC4.icl.win32
Windows ME.  Pentium 4.
Odd file names for files created with the following INI options.
Debug_File=true
    produces file named:  render.out
Fatal_File=true
    produces file named:  stats.out
Render_File=true
    produces file named:  warning.out
Statistic_File=true
    produces file named:  alltext.out
Warning_File=true
    produces file named:  Steve A. Bennett
All_File=true
    produces file named:  David K. Buck
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Subject: Re: Text Streams to Odd File Names
Date: 16 May 2002 08:23:21
Message: <3ce3a4b8@news.povray.org>
Robert Chaffe <rob### [at] earthlinknet> wrote:
> Warning_File=true
> All_File=true
  So what's wrong with this?-)
Date: 16 May 2002 09:06:17
Message: <slrnae7bkv.j80.tontonTh@trabent.nfrance.com>
In article <3ce3a4b8@news.povray.org>, Warp wrote:
>> Warning_File=true
>> All_File=true
      not 8.3 compliant ?
| > sur le meme disque. par contre pour se l'instalation de logicielle alors
| > la ces la galer totale, je ne suis pas ariver a en instaler un seul.
| moins bien.			-+- remarque acide dans fcol.debats -+-
Date: 16 May 2002 11:24:13
Message: <3ce3cf1c@news.povray.org>
tontonTh <ton### [at] labuvetteorg> wrote:
>       not 8.3 compliant ?
  Why should it be?
  AFAIK POV-Ray 3.5 has not been ported to any system with that limitation.
Date: 16 May 2002 11:56:15
Message: <3ce3d69f@news.povray.org>
>>       not 8.3 compliant ?
>   Why should it be?
>   limitation.
MS-DOS? OK, *has* not been ported, but will probably.
Felix Wiemann
Date: 16 May 2002 12:15:40
Message: <3ce3db2c$1@news.povray.org>
news:3ce3a4b8@news.povray.org...
> > Warning_File=true
> > All_File=true
There is nothing wrong with file names,
but they should be different according to docs:
5.2.5.3  Directing Text Streams to Files:
Statistic_File=true Echo statistic text to STATS.OUT
Render_File=true Echo render info text to RENDER.OUT
Warning_File=true Echo warning info text to WARNING.OUT
All_File=true Echo all debug, fatal, render, statistic, and warning text to
ALLTEXT.OUT
It looks like there is a wrong index shift in array with file names.
Date: 16 May 2002 12:18:52
Message: <3ce3dbec@news.povray.org>
There isn't any text file created on my system, just the output picture.
RC4, SuSE Linux 7.3, P3 600, 128MB
Felix Wiemann
Date: 16 May 2002 12:22:04
Message: <3ce3dcac$1@news.povray.org>
"Robert Chaffe" <rob### [at] earthlinknet> wrote in message
news:3ce31865@news.povray.org...
> Debug_File=true
> Fatal_File=true
> Render_File=true
> Statistic_File=true
> Warning_File=true
> All_File=true
Confirmed,
P3 W2K
Also reported with previous beta:
http://news.povray.org/povray.beta-test/23412/?ttop=24438&toff=150
Date: 16 May 2002 12:34:46
Message: <3ce3dfa6@news.povray.org>
  Well, then it will be the headache of the one who is doing the port, not
the team, don't you think?
Date: 16 May 2002 12:41:50
Message: <d7o7eu0bfefm46akgot2euq2f1bo44276p@4ax.com>
From documentation: "POV-Ray is intended to be very portable. This isn't just
an issue of philosophy or purism, POV-Ray is really used on a large variety of
different platforms".
ABX
