POV-Ray : Newsgroups : povray.beta-test : Text Streams to Odd File Names Server Time
27 Apr 2026 05:49:09 EDT (-0400)
  Text Streams to Odd File Names (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Text Streams to Odd File Names
Date: 16 May 2002 11:24:13
Message: <3ce3cf1c@news.povray.org>
tontonTh <ton### [at] labuvetteorg> wrote:
>       not 8.3 compliant ?
  Why should it be?
  AFAIK POV-Ray 3.5 has not been ported to any system with that limitation.
Date: 16 May 2002 11:56:15
Message: <3ce3d69f@news.povray.org>
>>       not 8.3 compliant ?
>   Why should it be?
>   limitation.
MS-DOS? OK, *has* not been ported, but will probably.
Felix Wiemann
Date: 16 May 2002 12:15:40
Message: <3ce3db2c$1@news.povray.org>
news:3ce3a4b8@news.povray.org...
> Robert Chaffe <rob### [at] earthlinknet> wrote:
> > Warning_File=true
> >     produces file named:  Steve A. Bennett
> > All_File=true
> >     produces file named:  David K. Buck
>   So what's wrong with this?-)
There is nothing wrong with file names,
but they should be different according to docs:
5.2.5.3  Directing Text Streams to Files:
Statistic_File=true Echo statistic text to STATS.OUT
Render_File=true Echo render info text to RENDER.OUT
Warning_File=true Echo warning info text to WARNING.OUT
All_File=true Echo all debug, fatal, render, statistic, and warning text to
ALLTEXT.OUT
It looks like there is a wrong index shift in array with file names.
Date: 16 May 2002 12:18:52
Message: <3ce3dbec@news.povray.org>
Robert Chaffe wrote:
> Version 3.5.beta.RC4.icl.win32
> Windows ME.  Pentium 4.
> Odd file names for files created with the following INI options.
There isn't any text file created on my system, just the output picture.
RC4, SuSE Linux 7.3, P3 600, 128MB
Felix Wiemann
Date: 16 May 2002 12:22:04
Message: <3ce3dcac$1@news.povray.org>
"Robert Chaffe" <rob### [at] earthlinknet> wrote in message
news:3ce31865@news.povray.org...
> Debug_File=true
>     produces file named:  render.out
> Fatal_File=true
>     produces file named:  stats.out
> Render_File=true
>     produces file named:  warning.out
> Statistic_File=true
>     produces file named:  alltext.out
> Warning_File=true
> All_File=true
Confirmed,
P3 W2K
Also reported with previous beta:
http://news.povray.org/povray.beta-test/23412/?ttop=24438&toff=150
Date: 16 May 2002 12:34:46
Message: <3ce3dfa6@news.povray.org>
  Well, then it will be the headache of the one who is doing the port, not
the team, don't you think?
Date: 16 May 2002 12:41:50
Message: <d7o7eu0bfefm46akgot2euq2f1bo44276p@4ax.com>
From documentation: "POV-Ray is intended to be very portable. This isn't just
an issue of philosophy or purism, POV-Ray is really used on a large variety of
different platforms".
ABX
Date: 16 May 2002 12:59:09
Message: <3ce3e55d@news.povray.org>
"very portable" does not mean "portable to every stoneage system".  I am sure
POV-Ray won't run on any 8 or 16 bit operating system or hardware with the
exception of x86...
    Thorsten
e-mail: tho### [at] trfde
Date: 16 May 2002 13:04:32
Message: <3ce3e6a0@news.povray.org>
BTW, did I mention it will be fixed in the next beta?  It had been so funny to
watch the discussion in this thread develop that I probably forgot... ;-)
    Thorsten
Date: 16 May 2002 13:08:18
Message: <glp7eucq9sn23lb01gseglhdmur8t1kdrn@4ax.com>
On Thu, 16 May 2002 19:04:31 +0200, "Thorsten Froehlich" <tho### [at] trfde>
No. But it's fixed now ;-)
ABX
