POV-Ray : Newsgroups : povray.beta-test : CodesMax-Behaviour with other files than .pov, .inc, .ini Server Time
12 Oct 2025 00:40:47 EDT (-0400)
  CodesMax-Behaviour with other files than .pov, .inc, .ini (Message 1 to 5 of 5)
Subject: CodesMax-Behaviour with other files than .pov, .inc, .ini
Date: 13 May 2002 12:02:34
Message: <3cdfe39a$1@news.povray.org>
Hi!
This is a little thing:
Some betas before this worked:
-Make a new File (New-Button)
-Write a C-Program (for example. Just something that's not .pov, .ini, .inc)
-And now, try to save the file as foobar.c
There seems no way to surpress the renaming to foobar.c.pov (even if I select
"all Files" before typing the name.)
Well, I like to use the "povray-Editor" (this codexmax-thingie) to edit other
files than .pov, too. So I can change quick to a pov-file and render between
programing :-) .
This didn't work with 3.1 as well, but some beta-version did that wanted
behaviour, they let me save my file directly to the name, i want. Now, I have
to rename it by hand and reopen it in the editor...
I was using RC3 the last time, so maybe this is outdated. (sorry)
And if it was a bug, that caused the "nice" behaviour than I'm shutting up...
Thank you!
cukk
Subject: Re: CodesMax-Behaviour with other files than .pov, .inc, .ini
Date: 13 May 2002 23:48:23
Message: <3ce08907@news.povray.org>
KalleK wrote in message <3cdfe39a$1@news.povray.org>...
.inc)
select
As far as I can tell, this is a Windows problem.  Take it up with Microsoft.
Mark
The Universe is expanding.
The budget for its exploration is shrinking.
Date: 14 May 2002 10:11:54
Message: <3ce11b2a$1@news.povray.org>
"KalleK" <kal### [at] gmxde> wrote in message news:3cdfe39a$1@news.povray.org...
> Hi!
Hmm, under win2000, the solution is the same as notepad - put your filename in
quotes.
So, save "test.c" not test.c
Date: 14 May 2002 13:59:55
Message: <3ce1509b$1@news.povray.org>
Hi Tom!
And it works with Win98, too. Thank you!
(It's just, that for some beta-versions it worked without quotes, but this is
a not to complicated workaround.)
cukk
Date: 17 May 2002 11:48:06
Message: <3ce52636@news.povray.org>
-Hail
  If you look at Adobe Photoshop's save dialog you will see two options you
can check, they are: append extension and save extension as lower case. I
believe POV should have something similar.
