![](/i/fill.gif) |
Skiba <abx### [at] babilon org> wrote:
> What values should I use to be compliant with suggestion in 5th and 6th line ?
The message is generic and does *not* mean you have to change the values. It
is only a *recommendation*. Essentially this happens mostly if you use
evaluate with a very simple function for which evaluate isn't really needed...
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 13 May 2002 13:03:32 +0200, "Thorsten Froehlich" <tho### [at] trf de>
Yes, yes, I know, as I said it is not very important report. Variation of
maximum gradient is 0 so in such case further use of evaluate has no sense
afaik.
I used this for very complex function. It was IC_Text("ISO-CSG Library",1,0))
from iso_csg library.
ABX
![](/i/fill.gif) |
