POV-Ray : Newsgroups : povray.beta-test : Functions more than 65535 Server Time
4 Jun 2026 05:43:29 EDT (-0400)
  Functions more than 65535 (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Functions more than 65535
Date: 12 May 2002 14:50:25
Message: <3cdeb971@news.povray.org>
In article <3cdea2bc@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
>> What the hell are you doing with such complex function? ;-)
>   65535 functions and 128 recursion levels should be enough for anyone.
Long, long ago the limit was a sufficient 256 operations per function... :-)
> As well as 640 kilobytes of memory. ;)
No, the VM won't be too happy with such a small amount of memory - with 2^16
functions and 2^16 instructions per function and the instructions usually
taking 4 bytes each you end up with 16 GB...
But who needs 64 bit address space? ;-)
    Thorsten
e-mail: tho### [at] trfde
Date: 12 May 2002 14:54:19
Message: <3CDEBA5B.A6AA7104@gmx.de>
Thorsten Froehlich wrote:
> > BTW, in the list of limits in docs section 6.1.6.2 am missing something
> > about the limit of nesting functions, i quite frequently get the error:
> > 'Maximum function evaluation recursion level reached.'
> It is 128.
User-Defined Float Functions':
Limits:
- The maximum recursion depth for nesting functions is 128.
Oh come on, povers are commonly not known for their temperance...
Constructions like the following are very useful, but regularly exceed
this limit.
#while (...)
  #local fn_new1 = function { fn_1(x, y, z) + fn_foo(x, y, z)
  #undef fn_1
  #local fn_1 = function { fn_new1(x, y, z) }
  #undef fn_new1
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 12 May 2002 15:04:41
Message: <Xns920CD6E78133Aseed7@povray.org>
in news:3CDEBA5B.A6AA7104@gmx.de Christoph Hormann wrote:
> Ingo: I would suggest something like the following in
> Limits:
Unless it changes the meaning completely, I think I'll leave out the word
"recursion", to prevent the idea that recursive functions are possible.
Ingo
Date: 12 May 2002 15:06:01
Message: <3cdebd19@news.povray.org>
In article <3CDEBA5B.A6AA7104@gmx.de> , Christoph Hormann
> Limits:
In the docs this should be 1024 sand not 128.  Guess why! ;-)
BTW, the parameter limit is 56 and not 40 anymore.  This changed some time
ago. So the entry should be "The maximum number of allowed parameters per
function is 56"
    Thorsten
Date: 12 May 2002 16:50:58
Message: <3cded5b2$1@news.povray.org>
> this limit.
> #while (...)
>   #undef fn_1
>   #undef fn_new1
> #end
So essentially what you want is a "sum" function?
    Thorsten
Date: 12 May 2002 17:10:05
Message: <3CDEDA2C.8504C17C@gmx.de>
I'm not sure what you mean by 'sum' function, but of course this example
was very simple, usually there are a lot of '#if's etc. too.
Date: 12 May 2002 17:32:45
Message: <3cdedf7d$1@news.povray.org>
In article <3CDEDA2C.8504C17C@gmx.de> , Christoph Hormann
For example allowing functions equivalent to
10
 >  i*2+4
i=1
inside functions, would that help?
    Thorsten
Date: 12 May 2002 17:58:24
Message: <3CDEE57F.29ECF6D5@gmx.de>
> 10
>  >  i*2+4
> i=1
That would be nice but it would not help much in this particular case and
is in fact not necessary since this can already be done using #while
inside functions.  In the example i gave i could have put a 'function {}'
around the while loop, leave out the #declare's and just sum up things
with the loop, this would avoid the recursion problem, but this does not
work if you build several functions in the while loop and don't want to
split into separate loops for speed reasons.
Date: 12 May 2002 18:00:58
Message: <3CDEE617.73DE8699@gmx.de>
All right.
Date: 13 May 2002 02:19:37
Message: <3cdf5af9@news.povray.org>
In article <3CDEE57F.29ECF6D5@gmx.de> , Christoph Hormann
> inside functions.
Keep in mind that the "1" and "10" could be expressions and it is also
faster...  ;-)
    Thorsten
