POV-Ray : Newsgroups : povray.beta-test : A small change request prior to the release of the POV 3.5 final Server Time
17 Feb 2026 19:02:50 EST (-0500)
  A small change request prior to the release of the POV 3.5 final (Message 1 to 10 of 12)
Subject: A small change request prior to the release of the POV 3.5 final
Date: 10 May 2002 10:29:52
Message: <3cdbd960$1@news.povray.org>
Can the number of pixels per second estimate be changed to a floating point
number with at least three digits past the decimal point, instead of an
integer. I am referring to the Windows GUI version when I say this and for
very slow renders it would be very helpful to see more information than 0
Pixels Per Second for the current line.
Subject: Re: A small change request prior to the release of the POV 3.5 final
Date: 10 May 2002 10:36:18
Message: <3CDBDADF.566B533C@gmx.de>
Maybe you should try rendering a 0 PPS scene and see what happens before
complaining...
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 10 May 2002 10:36:33
Message: <5imndu04uiqs5o706f4npenh0r3qh8dhlp@4ax.com>
On Fri, 10 May 2002 09:29:31 -0500, "Michael Goldshteyn" <mik### [at] wwacom>
have you checked how it works in 3.5 ?
from documentation:
"Note that on extremely slow renders, the PPS indicator may change to showing
PPM (pixels per minute), or PPH (pixels per hour)."
ABX
Date: 10 May 2002 10:38:15
Message: <3cdbdb57$1@news.povray.org>
I am as we speak and I see (last line: 0 PPS)
news:3CDBDADF.566B533C@gmx.de...
point
for
0
> complaining...
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Date: 10 May 2002 10:41:03
Message: <3cdbdbff$1@news.povray.org>
Here is the status line from a current render using RC5:
Download 'status.bmp.dat' (2 KB)
Date: 10 May 2002 10:48:05
Message: <ptmndu82g6vum6f67h9jmljebgds1fjrdp@4ax.com>
On Fri, 10 May 2002 09:37:54 -0500, "Michael Goldshteyn" <mik### [at] wwacom>
Try to start render with +GAout.txt. You will achive file out.txt with time of
every line. Calculation is easy then.
ABX
Date: 10 May 2002 10:49:55
Message: <3cdbde13$1@news.povray.org>
True, but as a small convenience, it would be nice to see the average PPS
time as a floating point number to some number of decimal places.
Mike
news:ptmndu82g6vum6f67h9jmljebgds1fjrdp@4ax.com...
time of
> ABX
Date: 10 May 2002 10:51:22
Message: <aenndu484jcf6abs91a4gr9ckdjb36k9vn@4ax.com>
On Fri, 10 May 2002 09:40:42 -0500, "Michael Goldshteyn" <mik### [at] wwacom>
wrote:
> Here is
That's not binary group.
Perhaps it uses always the same unit as second part of counter on right side.
> using RC5:
What ? :)
ABX
Date: 10 May 2002 10:55:09
Message: <3cdbdf4d@news.povray.org>
news:aenndu484jcf6abs91a4gr9ckdjb36k9vn@4ax.com...
> wrote:
> > Here is
side.
Maybe that's the problem!
> > using RC5:
> What ? :)
Oops, I meant RC4, a typo ;)
> ABX
Date: 10 May 2002 11:13:31
Message: <3CDBE394.7C424F00@gmx.de>
You are probably doing something wrong, i read '6 PPM' currently.
