RC3, SuSE Linux 7.3, P3 600, 128MB RAM
When I use values for turbulence above 2^31 (2 billions), white areas
appear. The bigger the values the bigger the areas. The following scene
shows the 'problem':
camera{orthographic location z * -10 look_at 0 right x * 8 up y * 6}
plane
-z, 0
pigment
checker color rgb 1 color rgb 0
warp
turbulence 10000000000
finish{ambient 1}
I don't know if it's possible or even worth to fix it, but such high
values could perhaps be used for some noise in only one direction.
Maybe using some floating point type instead of int would solve the
problem and be also more accurate.
Felix Wiemann
On Mon, 06 May 2002 15:42:53 +0200, Felix Wiemann <Fel### [at] gmx net>
Turbulence has neither float nor integer as parameter.
It use vector parameter! Shortcut with float as vector
is first example of 6.7.12.6.3 chapter. I wonder what
suggested to you it should be integer ?
ABX
Sorry, I haven't been clear enough. I actually refered to the source. I
guess it's a problem of int (or long int) due to the 2^31 limit.
Felix Wiemann
> appear.
And that surprises you?
When we go to the extremes, floating point accuracy errors usually give
funny results.
Why do you think that any part of turbulence calculations use ints? AFAIK
it's all floating point.
On Mon, 06 May 2002 16:59:10 +0200, Felix Wiemann <Fel### [at] gmx net>
IIRC every number is readed from scripts as float. Only if internal
representation requires integer then it is converted.
ABX
> give
> funny results.
At exactly 2^31?
> AFAIK
Because this is a limit typical for int.
Felix Wiemann
In article <3cd69991@news.povray.org> , Warp <war### [at] tag povray org> wrote:
Noise uses ints and noise is used by turbulence. However, your point is of
course still valid - using numbers of this size will never yield a precise
enough result. Nor is there really any use for such a turbulence value.
Thorsten
e-mail: tho### [at] trf de
In article <3cd6875a@news.povray.org> , Felix Wiemann <Fel### [at] gmx net>
No, what you are trying is close to pointless. It will break very early along
the way - even long before this limit! Of course, if you really want to be
floating-point accuracy (which is the issue long before hitting this
particular limit) to be part of your turbulence you can use it.
Thorsten
Another simple example of where accuracy errors kick in is the
following:
camera { location -z*100000 look_at 0 angle .002 }
light_source { <100,200,-300>, 1 }
sphere { 0,1 pigment { rgb 1 } }
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
