POV-Ray : Newsgroups : povray.beta-test : orthographic camera renders object 'black' Server Time
25 Jul 2026 05:30:16 EDT (-0400)
  orthographic camera renders object 'black' (Message 1 to 4 of 4)
Subject: orthographic camera renders object 'black'
Date: 2 May 2002 16:46:19
Message: <3cd1a59b@news.povray.org>
This object renders fine with a regular camera, but when I switched to
orthographic, it has no shading whatsoever, moving the orthographic camera
very slighly off-center fixes the problem.
Jeff M
using version 3.5 beta, VC++ exe
Apologies if this is a known issue
// ROTARY SWITCH
   orthographic
//   location <0, 0.0001, -2>  // OK
   location <0, 0.000, -2>  // RENDERS 'BLACK' !!
   look_at <0, 0, 0>
light_source { <-15, 15, -4> color White }
prism {
    conic_sweep
   cubic_spline
    1, // sweep the following shape from here ...
    0.6, // ... up through here
    27, // the number of points making up the shape ...
< 0.965926, 0.258819 >,
< 0.900000, 0.000000 >,
< 0.965926, -0.258819 >,
< 0.866025, -0.500000 >,
< 0.636396, -0.636396 >,
< 0.500000, -0.866025 >,
< 0.258819, -0.965926 >,
< -0.000000, -0.900000 >,
< -0.258819, -0.965926 >,
< -0.500000, -0.866025 >,
< -0.636396, -0.636396 >,
< -0.866025, -0.500000 >,
< -0.965926, -0.258819 >,
< -0.900000, 0.000000 >,
< -0.965926, 0.258819 >,
< -0.866025, 0.500000 >,
< -0.636396, 0.636396 >,
< -0.500000, 0.866025 >,
< -0.258819, 0.965926 >,
< 0.000000, 0.900000 >,
< 0.258819, 0.965926 >,
< 0.500000, 0.866025 >,
< 0.636396, 0.636396 >,
< 0.866025, 0.500000 >,
< 0.900000, -0.000000 >,
    rotate <90,0,0>
    pigment { Grey }
Subject: Re: orthographic camera renders object 'black'
Date: 2 May 2002 16:52:06
Message: <3cd1a6f6@news.povray.org>
In article <3cd1a59b@news.povray.org> , "Jeff McClintock"
In your scene the camera plane will move into the object when using the
othographic camera.  You need to adjust your scene, this is not a bug in
POV-Ray.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 2 May 2002 19:03:08
Message: <3cd1c5ac@news.povray.org>
> POV-Ray.
  It would be nice if camera rays started from the plane which passes
through the camera location point (and is parallel to the viewing plane)
instead of starting from the projection plane.
Date: 6 May 2002 04:51:41
Message: <3cd6441d@news.povray.org>
> plane which passes through the camera location point
> (and is parallel to the viewing plane) instead of
I agree, I have never understood why it doesn't work that way...
Besides being much more logical and intuitive, it would also prevent
lots of confusion.
Rune
