POV-Ray : Newsgroups : povray.beta-test : Buglist 22 Apr 2002 (RC2) Server Time
25 Jul 2026 14:10:01 EDT (-0400)
  Buglist 22 Apr 2002 (RC2) (Message 31 to 34 of 34)
Subject: Re: Buglist 22 Apr 2002 (RC2)
Date: 5 May 2002 02:51:37
Message: <Xns92051D18BE4E6csbhccse@204.213.191.226>
John VanSickle <evi### [at] hotmailcom> wrote in news:3CD46365.433CEFA3
@hotmail.com:
>> Parsing fails on line 248 of shapes.inc when the Spheroid macro
>> attempts to use 'Center' as a parameter name.
> A consistent naming scheme will alleviate this problem.
> For instance, I prefix vector names with a v, scalars with s,
> index variables with i, and so on.
This is what I'd call putting the cart before the horse.
Given that shapes.inc and the other #macro-laden #includes are a standard
part of the distribution, I tend to think it'd make far more sense for them
to use a consistant naming scheme to stay out of the *users* hair rather
than for the user to go through all kinds of contortions to stay out of the
#include's hair.
I mean, you wouldn't like the idea of prefixing every name in a C program
with an underscore (etc) so it wouldn't collide with names used by the C
RTL, would you?  Of course not.  That's why the component names used by C
RTL are prefixed with underscores: so the user gets virtually the rest of
the non-defined namespace to himself/herself.
Date: 5 May 2002 02:57:30
Message: <Xns92051E17F8CBDcsbhccse@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3cd3a6f6@news.povray.org:
> It isn't a new limitation in 3.5 also you seem to give that impression.
Try this on 3.1:
#macro Center(Obj)
object {Obj}
#include "shapes.inc"
#declare X = sphere {0,1}
Center (X)
It won't choke.  Now try it on 3.5.  Now try to find anything in the
documentation that says this code is no longer valid under 3.5.
(Yes, I know /why/ it won't choke 3.1...  The reason why it won't choke 3.1
is irrelevant; the fact that it *does* choke 3.5 is the problem.)
> Having the same name twice in the same namespace simply cannot work.
Please tell that to the RC3 binary.  It copes just fine with #declared/
#localed names that match macro parameters:
#local X = function(x,y,z) {x+y+z}
#macro A(X) #end
Given that there's no valid reason to use the output of a macro to
determine the name of another macro's parameters, not performing macro
expansion during this portion of parsing seems reasonable for consistancy's
sake alone.  For instance, why should the code above work when #macro X()
#end #macro A(X) #end doesn't?
> the documentation explains the namespace rules.
In this specific case, telling the user that he/she can't do #macro A()
#macro B(A, D) is rather pointless when the user doesn't know that #macro B
(A, D) exists in the first place.  The point is that the standard includes
are consuming huge swaths of the namespace without any real documentation
or regard for what they might be stepping all over.  Finding safe names was
not a matter of luck with 3.1; it is very much a matter of luck with 3.5 as
soon as one #includes anything.  I don't think this change is particularly
rational or user friendly.
Again, if the parser cannot practically be fixed at this stage, could the
standard includes at least be modified so their macro parameter names are
all lower case (like all other Pov keywords), mangled to reduce the chances
of collisions with user macros, or added to the reserved keywords list in
docs section 6.1.1?
Date: 5 May 2002 13:39:13
Message: <3cd56e41@news.povray.org>
In article <Xns### [at] 204213191226> , che### [at] sympaticoca
> #macro A(X) #end
But that is a completely different case!  X is known to be a variable in both
cases and the variable namespace is well-defined.
You would be surprised what one can do (also the above can't be done) inside
macro parameter lists...
Because macros are in a completely different namespace.  In particular are
#macros behaving like macros and not functions (see <http://www.povray.org/
working-docs/id000153.html#6_2_8_3>) here.
As you know, #locals have a scope that is limited to files or the current
block while #macros are in a global namespace not really shareable with
#declares.  As POV-Ray identifiers are typeless there is significantly more
ambiguity when parsing such constructs.
As for the actual problem, by disallowing #declares (and anything that
implicitly declares an identifier) in parameter lists of #macro definitions
one can allow #macro identifiers as parameter names.  Nevertheless, this might
break some old scenes...
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 6 May 2002 18:41:35
Message: <3CD707D1.9A1840B7@hotmail.com>
> @hotmail.com:
> standard part of the distribution, I tend to think it'd make far more
> sense for them to use a consistant naming scheme to stay out of the
> *users* hair rather than for the user to go through all kinds of
> contortions to stay out of the #include's hair.
> program with an underscore (etc) so it wouldn't collide with names
> used by the C RTL, would you?  Of course not.  That's why the
> component names used by C RTL are prefixed with underscores: so the
> user gets virtually the rest of the non-defined namespace to
> himself/herself.
But I also use a consistent naming convention to avoid trampling
my own variables as well.
John
Rusty is rendering!
