POV-Ray : Newsgroups : povray.beta-test : Buglist 22 Apr 2002 (RC2) Server Time
25 Jul 2026 10:43:21 EDT (-0400)
  Buglist 22 Apr 2002 (RC2) (Message 11 to 20 of 34)
Subject: Re: Buglist 22 Apr 2002 (RC2)
Date: 22 Apr 2002 13:06:15
Message: <kbg8cu8e58nmighgg54rfho4c49bn2brdk@4ax.com>
On Mon, 22 Apr 2002 18:36:46 +0200, Christoph Hormann <chr### [at] gmxde>
wrote:
> Have you tried turning your monitor upside down and walking 3 times around
> the table before?
Thorsten said some day there is no magic in parser but message told me it is
an exception so I will perform this test next time :-)
ABX
Date: 22 Apr 2002 15:58:45
Message: <3cc46b75@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> I still get a crash with the second problem from:
> http://news.povray.org/3CB1B39A.3F70A85A%40gmx.de
  It would be really nice to get a short (and undivided) example code that
demonstrates this. It's not nice to have to get some include file from
somewhere.
Date: 23 Apr 2002 07:42:00
Message: <3CC54881.BC5FFDD5@gmx.de>
> somewhere.
All right, but i'm afraid it's no more that short then.
// BEGIN POV-Code
  location <0.2,0.2,-1>
  look_at  <0,0,0>
  right (4/3)*x
light_source {
  <1000, 2500, -5000>
  color rgb 1.2
#include "transforms.inc"
#declare IC_Arr=array[12]
#macro IC_Merge_Array(Array)
  #local Size=dimension_size(Array,1);
  function {
    min(
      #local Counter=0;
      #while (Counter<Size)
        #if (Counter>0) , #end
          Array[Counter] (x,y,z)
        #local Counter=Counter+1;
#macro IC_Matrix (Fn, Mtrx)
  function {
    Fn(x*Mtrx[0][0] + y*Mtrx[0][1] + z*Mtrx[0][2],
       x*Mtrx[1][0] + y*Mtrx[1][1] + z*Mtrx[1][2],
       x*Mtrx[2][0] + y*Mtrx[2][1] + z*Mtrx[2][2])
#macro IC_RotateR (Fn, Vect)
  #local Vect=Vect+<0,0,0>;
  #local Cx=-Vect.x;
  #local Cy=-Vect.y;
  #local Cz=-Vect.z;
  #local MtrxA=array[3][3]
  #local MtrxB=array[3][3]
  #local MtrxC=array[3][3]
  #local MtrxA[0][0] = 1.0;
  #local MtrxA[0][1] = 0;
  #local MtrxA[0][2] = 0;
  #local MtrxA[1][0] = 0;
  #local MtrxA[1][1] = cos(Cx);
  #local MtrxA[1][2] = -sin(Cx);
  #local MtrxA[2][0] = 0;
  #local MtrxA[2][1] = sin(Cx);
  #local MtrxA[2][2] = cos(Cx);
  #local MtrxB[0][0] = cos(Cy);
  #local MtrxB[0][1] = 0;
  #local MtrxB[0][2] = sin(Cy);
  #local MtrxB[1][0] = 0;
  #local MtrxB[1][1] = 1;
  #local MtrxB[1][2] = 0;
  #local MtrxB[2][0] = -sin(Cy);
  #local MtrxB[2][1] = 0;
  #local MtrxB[2][2] = cos(Cy);
  #local MtrxC[0][0] = cos(Cz);
  #local MtrxC[0][1] = -sin(Cz);
  #local MtrxC[0][2] = 0;
  #local MtrxC[1][0] = sin(Cz);
  #local MtrxC[1][1] = cos(Cz);
  #local MtrxC[1][2] = 0;
  #local MtrxC[2][0] = 0;
  #local MtrxC[2][1] = 0;
  #local MtrxC[2][2] = 1;
  #local fn_X=IC_Matrix (function(x, y, z){ Fn(x, y, z) }, MtrxA)
  #local fn_Y=IC_Matrix (function(x, y, z){ fn_X(x, y, z) }, MtrxB)
  IC_Matrix (function(x, y, z){ fn_Y(x, y, z) }, MtrxC)
#macro IC_Rotate (Fn, Vect)
  #local Cx=(Vect.x/180)*pi;
  #local Cy=(Vect.y/180)*pi;
  #local Cz=(Vect.z/180)*pi;
  IC_RotateR (function(x, y, z){ Fn(x, y, z) }, <Cx, Cy, Cz>)
#macro IC_Cone (Start, Radius1, End, Radius2)
  #local Start=Start+<0,0,0>;
  #local Cx=Start.x;
  #local Cy=Start.y;
  #local Cz=Start.z;
  #local Len=vlength(End-Start);
  #if (Len=0)
    #error "iso_csg.inc: Error: zero height cone"
  #local fn_T=function { Reorient_Trans(End-Start, x)  }
  #local fn_X=function(x, y, z){
    max(sqrt(y^2 + z^2) - Radius1+x*((Radius1-Radius2)/Len), -x, x-Len)
  #local fn_Y=
  function(x, y, z){
    fn_X(fn_T(x, y, z).x,
         fn_T(x, y, z).y,
         fn_T(x, y, z).z)
  function {
    (fn_Y((x-Cx),(y-Cy),(z-Cz)))
  function {
    min(
      #local Counter=0;
#declare IC_Arr[0]=IC_Cone(0, 0, x+y, 1)
#declare IC_Arr[1]=IC_Rotate(IC_Arr[0], 30*z)
#declare IC_Arr[2]=IC_Rotate(IC_Arr[1], 60*z)
#declare IC_Arr[3]=IC_Rotate(IC_Arr[2], 90*z)
#declare IC_Arr[4]=IC_Rotate(IC_Arr[3], 120*z)
#declare IC_Arr[5]=IC_Rotate(IC_Arr[4], 150*z)
#declare IC_Arr[6]=IC_Rotate(IC_Arr[5], 180*z)
#declare IC_Arr[7]=IC_Rotate(IC_Arr[6], 210*z)
#declare IC_Arr[8]=IC_Rotate(IC_Arr[7], 240*z)
#declare IC_Arr[9]=IC_Rotate(IC_Arr[8], 270*z)
#declare IC_Arr[10]=IC_Rotate(IC_Arr[9], 300*z)
#declare IC_Arr[11]=IC_Rotate(IC_Arr[10], 330*z)
#declare fn_XX= IC_Merge_Array(IC_Arr)
isosurface
  function { fn_XX(x, y, z) }
  max_gradient 1.6
  contained_by { box { -2, 2 } }
  pigment { rgb <0, 0.2, 1.1> }
  finish { specular 0.3 }
  scale 0.1
// END POV-Code
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 23 Apr 2002 10:19:42
Message: <8vqacu4as77ojv54hshn94rdn4b4ar9u60@4ax.com>
On 21 Apr 2002 19:41:55 -0400, Warp <war### [at] tagpovrayorg> wrote:
> I might have missed some bugs reported since the last buglist, so feel
> free to reply with a note.
>  Officially confirmed bugs:
Probably nothing to worry about but ... In changes.txt there is note about
Change 1523 : "Partial fix for radiosity recursion problems" in RC2 section.
If it is a partial fix then there must be something left still not work. But
there is no note in your list about anything like official not fixed bug in
radiosity.
ABX
Date: 23 Apr 2002 11:01:12
Message: <3cc57738@news.povray.org>
Ok, noted. (Although a shorter example would have been nicer...)
Date: 23 Apr 2002 11:11:32
Message: <3cc579a3@news.povray.org>
Curiously it doesn't crash in the unix version...
Date: 23 Apr 2002 11:16:31
Message: <dkuacusdpe57c3blp8a5fh6rsngtibui34@4ax.com>
Confirm crash of this shorter version of script on
POV 3.5 RC2 icl on WinNT Sp 6 PII 233 with 128 MB
ABX
Date: 23 Apr 2002 12:30:31
Message: <3cc58c27@news.povray.org>
> radiosity.
Because there is change 1526...
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Apr 2002 12:44:55
Message: <0i3bcu4pte94ifedlcn2u2eqipbrc41dqc@4ax.com>
On Tue, 23 Apr 2002 18:30:26 +0200, "Thorsten Froehlich" <tho### [at] trfde>
Then the name of 1526 fix should be fixed to "Final fix for radiosity
recursion problems" in next RC then ;-)
YKIHBRTL
Date: 23 Apr 2002 13:05:59
Message: <el4bcugnvpi6g74lm0od6etuiutme91vn7@4ax.com>
On Tue, 23 Apr 2002 13:41:53 +0200, Christoph Hormann <chr### [at] gmxde>
After walking around rotated monitor I have good news for you Chris :-).
On my tests crash disappear when sequence of:
is replaced with short
  #local f_T=function{transform{rotate -Vect}};
  function{Fn(f_T(x,y,z).x,f_T(x,y,z).y,f_T(x,y,z).z)}
It not changes that your macros shouldn't crash however you can make stable
version. I think in correct form it shuld rather
transform{rotate Vect inverse}
ABX
