![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Last 2 lines below are not shown in commented colours. No error
message.
Version 3.5.beta.RC1 win32 (.msvc),
Win98SE, Celeron 500, 160MB.
Alf
/* This is a comment
// This too
/* This also */
#declare Nothing = sqrt(-1);
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> message.
That's a known problem caused by the codemax editor not supporting nested
comments. This will probably not be changed.
Last updated 16 Apr. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I haven't heard of a language in which that's allowed. Nested comments are
pretty regularly not allowed.
What *does* annoy me, however, is that the following, which should be
perfectly fine:
/* comment /* comment continued */
gives an error, saying that the openings and closings of comments don't
match. I think if nested comments aren't allowed, the program shouldn't
complain about improper nesting.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Now you have: The POV-Ray SDL.
> perfectly fine:
What do you mean "should be perfectly fine"? By what definition?
AFAIK there's no universal rule that says that nested comments must not
be supported by any language.
By the definition of the POV-Ray SDL, that code is bad because it lacks
a closing comment mark (two comments are opened but only one closed).
This is the corrected version:
/* comment /* comment continued */ */
What do you mean "nested comments aren't allowed"? Of course they are
allowed. And they work pretty fine.
The great thing about nested comments being supported is that if you
have a piece of code with lots of /*...*/ comments and then you want to
comment out the entire piece of code, it works just fine. For example in C
you just can't do it. (Well, in C you can do #if(0) ... #endif, but don't
expect any editor to color that block as a comment.)
The fact that the Codemax editor does not support coloring of nested
comments is unfortunate, but that doesn't make them unallowed. Coloring
means nothing to POV-Ray.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wait, POV-Ray allows nested comments?!?
*tests*
Woah! sweet! all this time I figured they weren't because the color coding
didn't support them! Hah...
Well, I feel silly. Resume your lives.
- Slime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> perfectly fine:
Patient: It hurts when I do this.
Doctor: Stop doing that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3cbe1353@news.povray.org> , "Slime" <noo### [at] hotmail com> wrote:
And how could it then determine if you want a part to be commented out or not?
If you think about what you are suggesting carefully you will find that what
you are expecting is mind-reading :-)
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Warp" <war### [at] tag povray org> wrote in message
news:3cbe163e@news.povray.org...
[snip]
you
to
This is exactly what I have always done since pov 2 in DOS. I'm new to
WinPov, wanted to play with 3.5 :) and wasn't aware of this codemax
error.
Alf
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
not?
what
Under my assumption that POV-Ray does not support nested comments, which has
been corrected, I would have expected it to behave like languages that
*don't* support nested comments, and simply ignore the second /*, since once
you're in a comment, the only thing that should be responded to is the
closing */.
- Slime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3cbee3b7$1@news.povray.org> , "Slime" <noo### [at] hotmail com> wrote:
> not?
> what
> closing */.
Ah, so you had not seen Christoph Hormann's response which already noted that
nested comments are support just not in the editor. It is really hard to
figure out when you responded because of the wrong date in your posts. All
your posts are over six days older...
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
