POV-Ray : Newsgroups : povray.beta-test : HF Macro Opinions Server Time
30 Sep 2024 09:12:47 EDT (-0400)
  HF Macro Opinions (Message 1 to 5 of 5)
Subject: HF Macro Opinions
Date: 9 Apr 2002 10:40:36
Message: <3cb2fd64@news.povray.org>
I'm rewriting the HF macros.
When using the HF macros and specifying a resolution of 20x20, what do you
want to get?
20x20 point = 19*19*2 triangles
or
21x21 points = 20*20*2 triangles
The build-in heightfield feature in POV-Ray use the first, i.e. a 20x20
pixels image give 19*19*2 triangles, but the HF macros don't nessesarily
have to work that way since samples can be taken on the fly.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Mar 19)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Subject: Re: HF Macro Opinions
Date: 9 Apr 2002 10:54:27
Message: <3CB300B8.66C3344B@gmx.de>
So, I'm not sure if this belongs into beta-test at all,
but I'd nontheless say, that 20x20 should result
in 19x19x2 triangles, because we use a 20x20 grid
for that, right?
> want to get?
> or
> Rune
Tim Nikias
Date: 9 Apr 2002 13:38:05
Message: <ol96bu0soid36fl81mofgo0nqac9vhqihd@4ax.com>
> want to get?
yes
ABX
Date: 9 Apr 2002 17:51:04
Message: <3cb36248$1@news.povray.org>
> want to get?
> or
I suppose it doesn't matter much, since one can always increase or decrease
the resolution by 1, but it would make more sense to me to have 20*20*2
triangles. If nothing else, I think this would simplify the macros a little
bit. (Loop i from 0 to width and j from 0 to height, taking samples at
(i/width, j/height).)
Anders
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Date: 10 Apr 2002 10:41:41
Message: <3cb44f25@news.povray.org>
I have a more generalized parametric surface generator which outputs a mesh2
#include file.  It turns an 20x20 point grid into a 19x19x4 group of
triangles by calculating interior centers through interpolation.  Its
parameters are two filenames, one for the input data and one for the
resulting file.  For your heightfield the input file would look this:
--- Start code ---
// Parametric variable form
#declare uMin = 0.0; // Minimum u value
#declare uMax = 1.0; // Maximum u value
#declare uNum = 100; // Number of points in u direction
#declare uWrap = 0; // u wraps around if != 0
#declare uSeed = 2252; // Random number seed for u parameter
#declare vMin = 0; // Minimum v value
#declare vMax = 1.0; // Maximum v value
#declare vNum = 100; // Number of points in v direction
#declare vWrap = 0; // v wraps around if != 0
#declare vSeed = 7335; // Random number seed for v parameter
#declare IsRnd = false; // True if random number used
#declare Detail = "Partial"
/* Detail values
  Verbose = Line by line details
  Partial = Operations only
  Other = Filename only
/* For all macro functions
 i = Current value of u parameter
 j = Current value of v parameter
 p = Current value of u variance (0...1)
 q = Current value of v variance (0...1)
// Optional variables and subfunctions
#declare hfAltitide = function { pattern { granite } }
// point function
#macro pnt(i, j, p, q)
    <i, hfAltitide(i,0,j), j>
#declare Smooth = 0; // Smooth flag
--- End code ---
I found that using an include file for large numbers of parameters is much
easier and error-free than putting all of them in the function definition.
This also gets around any difficulties with passing macro names to other
macros.
This more general macro could simply replace the HF_Macros and a few others
besides.  I could submit it to the POV-Team for inclusion if people want it.
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3CB300B8.66C3344B@gmx.de...
> for that, right?
you
> > want to get?
> > or
> > Rune
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
