POV-Ray : Newsgroups : povray.beta-test : New uv_mapping bug in beta 15 Server Time
30 Mar 2026 23:13:09 EDT (-0400)
  New uv_mapping bug in beta 15 (Message 1 to 2 of 2)
Subject: New uv_mapping bug in beta 15
Date: 1 Apr 2002 13:04:02
Message: <3ca8a112$1@news.povray.org>
Using the uv_mapping command inside a texture statement (in accordance with
the documentation) gives a parsing error: "No matching } in 'pigment',
uv_mapping found instead".
eg:
      uv_mapping pigment {
        image_map { jpeg "texture.jpg" }
       ... normal ... finish ... etc ...
The documentation states the uv_mapping syntax as follows:
    uv_mapping pigment { PIGMENT_BODY } | pigment { uv_mapping
PIGMENT_BODY }
    uv_mapping normal  { NORMAL_BODY  } | normal  { uv_mapping
ORMAL_BODY  }
    uv_mapping texture { TEXTURE_BODY } | texture { uv_mapping
TEXTURE_BODY )
so surely the above example should work?
The POV-Ray/scenes/objects/mesh.pov file also gives the error.
This bug has only appeared in beta 15, which has a uv_mapping fix which
disallows the uv_mapping command in function patterns - could this be the
reason?
win98 256MB PII & 512MB PIII - pov3.5.beta.15.icl.win32
Subject: Re: New uv_mapping bug in beta 15
Date: 1 Apr 2002 14:50:30
Message: <3ca8ba06@news.povray.org>
In article <3ca8a112$1@news.povray.org> , "Stephen Dartnall"
> reason?
Yes, this will be fixed in the next beta.
    Thorsten
e-mail: tho### [at] trfde
