3.5 Beta 13, Intel Compiled, Windows 2000.
I may be the only person to use <Ctrl>-Tab to cycle between document
panes...
If the "Messages" pane has the focus, and you type <Ctrl>+<Shift>+Tab
(which I think should do reverse cycle document pane)
you get a (system modal) dialog box with this message:
"The instruction at "0x77e13167" referenced memory at "0x00000000". The
memory could not be "written".
With on OK button to stop the program and Cancel to "debug".
It does not happen going forward (<Ctrl>+Tab).
It happens whether there are documents open or not.
"Scott Lambert" <sla### [at] niobrara com> schrieb im Newsbeitrag
news:3c9918ca@news.povray.org...
> panes...
No, you aren't...
Confirmed. But it also doesn't do the reverse cycle at all if I do
<Ctrl>+<Shift>+<Tab> on another pane.
So long,
Bonsai
On Wed, 20 Mar 2002 17:16:56 -0600, "Scott Lambert" <sla### [at] niobrara com>
confirmed crash
POV 3.5 b 13 icl on WinNT Sp 6 PII 233 with 128 MB
ABX
"Scott Lambert" <sla### [at] niobrara com> wrote in message
I can't replicate this (I also am running W2K).
-- Chris
(Actually, I get a send error report request box.)
Confirmed,
POV 3.5 b 13 icl on WinXP Pro Athlon XP 1500+, 224MB 266Mhz RAM
??? Win 2K should do it if both XP and NT do ???
For me:
<Ctrl>+Tab works normal,
<Ctrl>+<Shift>+Tab doesn't produce any response. OK in other apps.
3.5.beta.13.msvc.win32. Celeron 500, Win98SE, 160Mb
Alf
3.5 Beta 14 Intel; Windows 2000
Still there. (It's not in the list. Just trying to be thorough.)
> panes...
